Newsletter
Pocket GPS World :: View topic - Nuvi 250w - british voice
yvettebeames
PostPosted: Sat May 09, 2009 12:04 pm    Post subject: Nuvi 250w - british voice Reply with quote
Any way of getting a male british (normal, not clebrity) voice on this unit? I cannot stand the female one and have searched but only found British Dan that did not install.
PaulB2005
PostPosted: Sat May 09, 2009 12:11 pm    Post subject: Reply with quote
Hi and welcome.
If you use WebUpdater it should offer to install / update any normal voices onto the unit.
What do you mean by
What exactly did you do?
yvettebeames
PostPosted: Sat May 09, 2009 12:36 pm    Post subject: Reply with quote
I found a file on the garmin site that was an exe file and did not want to know. I then found an english_american_.vpm (male one) which I copied over the existing american female one on the unit and it works fine. I now have a male voice but I am still searching for a british male voice in .vpm format to write over the existing female one.
PaulB2005
PostPosted: Sat May 09, 2009 12:38 pm    Post subject: Reply with quote
You shouldn't have to overwrite anything. As i said if you use WebUpdater it'll offer to install any missing voices which should include British Male and Female voices. This will also ensure that the voices are intended for your unit.
yvettebeames
PostPosted: Sat May 09, 2009 12:48 pm    Post subject: Reply with quote
Used webupdater and it did have an update for the british voice (something to do with clarity) and I let it update and it was the same female again but louder! British Dan must be around somewhere in the correct format so I will carry on searching the net I guess. Thankyou for trying to help though.
PaulB2005
PostPosted: Sat May 09, 2009 1:12 pm    Post subject: Reply with quote
Is British Dan a voice that came with your unit? If so, why is it no longer on it. If not, do you not have another Male UK voice on there?
StuartStrangeboy
PostPosted: Sun May 10, 2009 7:45 am    Post subject: Reply with quote
What Garmin do you have?
PaulB2005
PostPosted: Sun May 10, 2009 10:26 am    Post subject: Reply with quote
Nuvi 250W
StuartStrangeboy
PostPosted: Mon May 11, 2009 12:56 pm    Post subject: Reply with quote
The English Dan is TTS I do believe so that would not work on the 250.
I will take a look at this though as I might create a standard voice.
20.052 (11 May 22)
