Pocket GPS World :: View topic - Help Please
Help Please
Post new topic   Reply to topic    Pocket GPS World Forum Index -> MyTomTom / TomTom HOME Desktop
mrgrimsby
PostPosted: Tue Mar 31, 2009 7:34 pm    Post subject: Help Please Reply with quote
I have just downloaded totom home 2.6 and it loads up every time i start my pc but I only want it to start when I click on it or connect my tomtom.
In preferences there does not seem to be a way to disable it starting up on widows boot up .....any advice ,as usual, would be very welcome, thank you.
Pete,
Isle Of Wight
richard345
PostPosted: Tue Mar 31, 2009 8:07 pm    Post subject: Re: Help Please Reply with quote
Pete, that's exactly what I wanted, but although I work in IT, I don't normally edit the Registry on my own machine - other people's, yes, but not my own.
While looking for something to complete a bad uninstall of a program, I found Revo Uninstaller. It has more tools than just an un-installer and I tried the Auto Start Manager and unchecked the TomTom HOME item and it works now just as I want. OK when I connect my TomTom, it runs though the drives and offers the usual options, but I cancel out of those screens until I am ready to start TT Home.
Might be worth a look?
Ric - TomTom 520 DEAD - Passed to the great traffic jam in the sky. Now using Maps & Waze on Samsung Galaxy S4 + CamerAlert of course!
PostPosted: Tue Mar 31, 2009 8:13 pm    Post subject: Reply with quote
In HOME:
Tools | Preferences
Untick Start TomTom HOME automatically when I connect my device to my computer (recommended)
Click 'Done'
Darren Griffin - Editor
richard345
PostPosted: Tue Mar 31, 2009 8:27 pm    Post subject: Reply with quote
In HOME:
Tools | Preferences
Click 'Done'
Darren, this didn't work for me, regrettably with Win XP Sp3. I thought it woud have sorted it, but no such luck Crying or Very sad
mrgrimsby
PostPosted: Tue Mar 31, 2009 8:38 pm    Post subject: Reply with quote
Thanks for the info, Richard I have ccleaner and it has a start up disable tool for this kind of thing and I forgot all about it until your recommendation .
Problem sorted, thanks again.
Pete.
PostPosted: Tue Mar 31, 2009 8:42 pm    Post subject: Reply with quote
Strange just tested under XP and mine doesn't auto-launch when the OS is rebooted.
mrgrimsby
PostPosted: Tue Mar 31, 2009 8:51 pm    Post subject: Reply with quote
Darren mine didn't used to load on start up before I downloaded the latest version but then it did and there was no preference tab that disabled it in tools which bugs me a bit, I have, as I said earlier, managed to use a third party application to stop it loading so all is well again, thanks again.
Pete
Isle Of Wight
PostPosted: Tue Mar 31, 2009 8:56 pm    Post subject: Reply with quote
Odd, mine was a fresh install done to test when I saw your post. Ho-hum, the joys of Windows. Yet one more reason why I don't.
dhn
PostPosted: Tue Mar 31, 2009 11:13 pm    Post subject: Reply with quote
In the root of the unit is a file called autorun.inf. It's a text file.
The contents look like this:
[autorun]
action=Run TomTom HOME
#open=InstallTomTomHOME.exe
label=TomTom
icon=tomtom.ico
[DeviceInstall]
#This section is empty; autorun will not install device drivers to your PC.
Try putting a # in front of the word 'action' using Notepad and see if the problem persists.
No promises ........... Rolling Eyes Shocked
PostPosted: Wed Apr 01, 2009 12:42 am    Post subject: Reply with quote
But the OP want's to stop Home running when Windows starts, before he plugs the TT in, so nothing on the TT itself will help...
To stop it running when Windows starts, you either need a utility like mentioned above or to do a quick registry tweak. That's how I did it.
Although I can't remember exactly what *I* did, here's a very good description of what to do from a previous post:
Under Windoze 2000 & XP and similar (I know nothing of Vista, Server 2008 & Windoze 7), you need to go into the Services console. This can be done by going into "Control Panel | Administrative Tools | Services", or from the "Run..." box or Command Prompt using "%SystemRoot%\system32\services.msc /s". ("%SystemRoot%" is a shortcut for what is usually, but not always, "C:\Windows" or "C:\WinNT"; "%Windir%" is another shortcut for pretty much the same thing. On most Windoze installations just typing "services.msc" instead of including the full path and the "/s" will suffice, but the full version caters for weird setups and makes sure you don't see any "Micro$oft Rox!" splash screens.)
You need to be a privileged user to do this, so you may need to run it as Administrator to get access.
Once there, scroll down to "TomTomHOMEService", right-click and choose "Properties". Change "Startup type" from "Automatic" to "Manual", then click "OK" and close the Services console. If you want to stop it as you make the change, rather than have it not start automatically when you next reboot, simply click "Stop" when you're changing its startup type.
Finally, to toggle the state of the service (i.e. start and stop it) without mucking around with opening and closing the Services console, use "net start TomTomHOMEService" and "net stop TomTomHOMEService" in the "Run..." box or at the command prompt.
(Original Post by "Jellyroll" is HERE)
The drawback to any of this though... once you've stopped it running at system startup, I don't think there is a way to get it to run when you plug the TomTom into the USB. I have to run it manually (which suits me anyway!)
philpugh
PostPosted: Thu Apr 02, 2009 2:17 pm    Post subject: Reply with quote
Unless I have missed something about the point of this thread... I get the same as Darren. I'm running XP SP3 and both TTHOME 2.5 and now the newer 2.6 behave as I expect. There is the TT icon in the system tray after booting and when I plug in my 520 (8.302) TTHome starts. I don't see the TTHOME main screen until after the unit is plugged in.
Phil
richard345
PostPosted: Thu Apr 02, 2009 3:44 pm    Post subject: Reply with quote
That's exactly it. The OP does not want the HOME Services running at boot up. When you see the icon in the System Tray, that's just what has happened.
By using one of the methods above, the intention is to prevent the service starting when it is not required, thus releasing resources on the machine.
I don't like odd programs having control, by stealth, of my laptop,!
PostPosted: Thu Apr 02, 2009 7:27 pm    Post subject: Reply with quote
you can try:
START
RUN
type: msconfig
under 'Startup' tab untick TomTom home
next time your pc restarts it will come up with a window saying something like 'your computer is running in a diagnostics mode' or similar then just tick the 'dont show this again' and you'll not be pestered again.
if needs must, you can revert back to how it was by simply runnning msconfig again and re-ticking tomtom home
PostPosted: Thu Apr 02, 2009 11:00 pm    Post subject: Reply with quote
MaFt wrote:
you can try:
START
RUN
type: msconfig
That would be a great method if 'Home' appeared in the "startup" list.... (but it doesn't)
There's one TomTom entry in the "services" tab, but I'm pretty sure I tried defeating that too.
TT seem to have got more and more devious about how Home gets started, and that's why it needed more devious methods to stop it!
Post new topic   Reply to topic    Pocket GPS World Forum Index -> MyTomTom / TomTom HOME Desktop All times are GMT + 1 Hour
21.094 (27 Sep 23)
