Pocket GPS World :: View topic - 7.7 poi issue
7.7 poi issue
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps
superleeds
PostPosted: Tue Feb 03, 2009 1:28 am    Post subject: 7.7 poi issue Reply with quote
Have upgraded to 7.7 but cannot seem to get custom poi to work .Tried to down load ov2 and convert to upi using 2.3 converter .Then used 2009 converter to update .However when i load poi into maps it doesnt show up.I have loaded the speedcams no issue but cant get custom poi to work..Any help please?
superleeds
PostPosted: Tue Feb 03, 2009 9:19 am    Post subject: Reply with quote
Update
Used mcguider for the time on a known camera route...Prog crashed at the first use of a camera....
scarymonkey
PostPosted: Tue Feb 03, 2009 10:18 am    Post subject: Reply with quote
Are you using a Symbian based phone? If so there is a bug in the current release that causes custom (and sometimes built in) POI to crash the application. Sygic are working on a fix (I believe it is in testin at present) which should be released via McGuider Assistant (check on the SD card if you have never used it) in the next few days/weeks.
Regarding the icons, what version of the database are you using? The icons in the consolidated download are 4 bit, but McGuider requires 8bit/256 colour. I can supply updated ones from the PGPSW download and have emailed them to MaFt so hopefully the future downloads of the database will have correct bit depth. PM me if you need them.
graemesimpson
PostPosted: Wed Feb 04, 2009 3:05 pm    Post subject: Reply with quote
The latest FIXED McGuider application is available from the "McGuider Assistant" download area.
The Custom POI problem is now fixed and you can use the PocketGPS SpeedCam files along with custom spoken warning sounds :-) some other tweaks to the application as well.
Graeme
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps All times are GMT + 1 Hour
22.043 (17 Apr 24)
