mike007 Regular Visitor
Posted: Thu Jan 29, 2009 6:14 pm Post subject: tomtom 1 V4 Poi ? |
Hi,is it possible to add my own custom poi file onto my ONE V4 ASSIST I have it on my pc can i transfer it onto the tom tom.
I have been searching the web and i can't believe that tom tom have omitted the custom poi categories from a brand new model,this is terrible i have just purchasefd a 1 V4 and thought it would be up to date(how wrong was i)
I use tomtom unit for work and now it's virtually useless ATM
I know there is a program or code to add your own poi category ,but i don't wanna mess up my tomtom is there a different way around it?
OR TOMTOM give us our custom poi back,whats the point of a GPS unit with no CUSTOM POI CATEGORIES  |
Posted: Thu Jan 29, 2009 6:25 pm Post subject: |
Unless i am missing something don't you just copy the OV2 file and BMP file to the map folder? |
philpugh Lifetime Member
Posted: Thu Jan 29, 2009 6:41 pm Post subject: |
Never tried a ONE (V anything) but...
Have you tried the "usual" way of adding custom POIs?
That is:
Copy the .ov2 (and any associated .bmp and .ogg) files into the map directory of the device. This directory's name will depend on the mapping you have (e.g. Western_Europe). If you are using .bmp and/or .ogg then the file names must EXACTLY match - including upper/lower case.
You should then be able to see the POI category when you go into manage POI (for example).
Certainly Page 20 of the ONE user manual implies that you can create POIs on the device! Worth a read as there is an advisory in the manual about being unable to access manage POIs until you have done something else! _________________ Phil |
Posted: Thu Jan 29, 2009 8:26 pm Post subject: |
Some of the newer One devices have a limited menu and have dropped the full Manage POI options from the menu, you can still use the "Warn When Near POI" and Navigate to POI is available so most functionality is there, its just not capable to add POI Categories while actually using the device on the road!
Putting a custom Menu on the device will often cure this issue and you get the missing menu page back, but you can certainly add POI files to the map folder on your device via your PC - Mike |
Posted: Fri Jan 30, 2009 4:47 pm Post subject: |
ok thanks ,I didn't realise i could still add my own files to the map folder thats great advice still no add poi category when on the road which is a shame,i guess i will have to use the favourites then make a poi category when i have to many I must have the LS model as in cars as opposed to the SRI model  |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Fri Jan 30, 2009 6:13 pm Post subject: |
mike007 wrote: | ok thanks ,I didn't realise i could still add my own files to the map folder thats great advice still no add poi category when on the road which is a shame,i guess i will have to use the favourites then make a poi category when i have to many I must have the LS model as in cars as opposed to the SRI model  |
Have a look at my post HERE - Manage POI files on a ONE v4 |
