Pocket GPS World :: View topic - Garmin 2820
Garmin 2820
orangewinger
PostPosted: Sat Jan 10, 2009 10:39 pm    Post subject: Garmin 2820 Reply with quote
Having trouble down loading voice file
I use POi down loaded to my c drive then unzipped
Using the POi to transfer to my 2820 but then say no data
Can any one help me
Orange winger
PostPosted: Sun Jan 11, 2009 1:02 am    Post subject: Reply with quote
Might not be possible....
Only Garmins with mp3 players can use the normal Garmin voice files. Some other models can use wav files and an older version of POILoader
See the notes on the voice download page:
WARNING: Only Nuvi models that have a mp3 player will support these mp3 format alerts. Other devices that lack mp3 support CANNOT utilise these alerts. A work-around using an older version of POILoader and wav file alerts can be found below.
Nuvi devices that do not support mp3 playback
For Nuvi devices that do not support mp3 playback there is an alternative option which you may wish to consider. This requires an Beta version of POILoader, v2.4.0 Beta available HERE. (5.15 Mb EXE Download).
Once installed you will need to convert the voice files provided above from mp3 to wav format. This can be done using a utility such as Audacity which is a free download available HERE. This method IS NOT supported by Garmin.
orangewinger
PostPosted: Mon Jan 12, 2009 10:25 pm    Post subject: voice data Reply with quote
Thanks Andy
my 2820 has capabilities for music ,will check it out to see if mp3 is compatable
If it is compatable should i use the Poi file to load?
Orangewinger
PaulB2005
PostPosted: Mon Jan 12, 2009 11:40 pm    Post subject: Reply with quote
What are the names of the files you have downloaded?
Are you using POILoader to transfer the files?
Are you doing this at the same time as the Speed Camera Database files?
orangewinger
PostPosted: Tue Jan 13, 2009 9:08 pm    Post subject: Reply with quote
Thanks for your reply
See below for info as from free POIs at the top of this page
Liz Whitaker
Last but by no means least in our trio of radio presenters, Liz works for 96.3 Radio Aire. Another likeable pleasant voice and my personal favourite. Available in a variety of versions with and without sirens if you really need them. ASH10 Camera Manager Version
UK (MPH) Voice Set
Orangewinger
PostPosted: Tue Jan 13, 2009 9:19 pm    Post subject: Reply with quote
Do you use the ASH10 Camera manager? If not then you should not use that version of the voice files?
PaulB2005
PostPosted: Wed Jan 14, 2009 1:22 am    Post subject: Reply with quote
As Darren says you should use the set that matches the Speed Camera Database you are using.
At the end of the day you should have matching triplicates of files with a CSV, a BMP and an MP3 with exactly the same names.
If you are using Ash10s Camera Manager use the set you downloaded. If not use one of the other 2 sets that are called " UK (MPH) Voice Set".
If it still doesn't work can you list a few of the CSV, BMP and MP3 files you have on your PC, in your POI upload folder.
Can you also answer
22.034 (27 Mar 24)
