Pocket GPS World :: View topic - Camera database question.
Dazp
PostPosted: Fri Nov 21, 2008 9:58 am    Post subject: Camera database question. Reply with quote
On my latest download, I have noticed all the bitmap images have a 'x2' by them ... whats this for, I'm sure they weren't on my last download or am I being dumb Laughing
IanS100
PostPosted: Fri Nov 21, 2008 10:09 am    Post subject: Reply with quote
The x 2 bitmaps give you the extra large icon in the top left corner of your screen
PostPosted: Fri Nov 21, 2008 12:09 pm    Post subject: Reply with quote
As v8.3 has changed the handling of POI Icons, the set we used to bundle results in a tiny icon at top left with 8.3.
So we decided to bundle the x2 size icons that have been available as an additional download for some time now. These give you the maximum size icon possible at top left.
Dazp
PostPosted: Fri Nov 21, 2008 12:19 pm    Post subject: Reply with quote
v8.3 is the software version for the latest Go's?
Mine is 7.163 will they work/do I need them on my Go?
PostPosted: Fri Nov 21, 2008 12:42 pm    Post subject: Reply with quote
x20 and x30 models only.
PostPosted: Fri Nov 21, 2008 5:17 pm    Post subject: Reply with quote
The software is for the x20/ x30 units but the x2 icons included in the download will work fine with your device - Mike
merlindriver
PostPosted: Wed Nov 26, 2008 9:57 pm    Post subject: Reply with quote
What about TT6 on a PDA - do the x2 bitmaps do anything and if not are they dormant or do I need to delete them from the Map folder on the SD card?
PostPosted: Wed Nov 26, 2008 10:01 pm    Post subject: Reply with quote
If you get a large Icon at top left of the map display then you can use these, if you don't then they are superfluous and can be deleted.
wibbly
PostPosted: Mon Dec 01, 2008 5:23 pm    Post subject: Reply with quote
I've a Go V2. Should the X2 files need to be renamed to work?
PostPosted: Mon Dec 01, 2008 5:25 pm    Post subject: Reply with quote
No. If your device supports X2 icons then it will use them, if it doesn't it will ignore them.
23.034 (26 Mar 25)
