Pocket GPS World :: View topic - Upgraded to v8, problems with PGPS Large Cam Icons?
Goto page 1, 2, 3, 4, 5, 6  Next
sdm197
PostPosted: Tue Nov 11, 2008 10:40 pm    Post subject: Upgraded to v8, problems with PGPS Large Cam Icons? Reply with quote
Hi All,
I upgraded to the new Navcore 8.300 map v805.1801, TT930 I have a question:
I use the bigger Icons downloaded from this site which show up in the top left corner of the TT screen when approaching a speed camera, since this update these icons are now tiny, I can no longer read some of them (The eyesight is not as good as it used to be!).
Would there be any fix for this, apart from going back to the previous navcore?
Thanks in advance,
SDM197.
PostPosted: Tue Nov 11, 2008 10:43 pm    Post subject: Reply with quote
Are you sure you still have the big icons installed? They still work as intended if installed? I have them running here on a 520 and 940 both running the latest release.
Did you copy them over to the new map?
sdm197
PostPosted: Tue Nov 11, 2008 11:21 pm    Post subject: Reply with quote
Hi Darren,
Well I certainly have not taken them off, unless the update did without me knowing?
Just checked they larger icons are still in the map folder they are the 48 type.
I have not installed a new map yet, although just downloading the new map as we speak.
SDM197.
PostPosted: Tue Nov 11, 2008 11:32 pm    Post subject: Reply with quote
Nope, you have done nothing wrong, this would appear to be yet another "feature" they have decided to remove/ knobble so it doesn't work:
TomTom One display with no x2 icon pack
TomTom One display with x2 icon pack
TomTom 930 with x2 icon pack running 8,3 software
I cannot put the earlier 8,010 release on the device for another screen capture as the map won't work and I will need to transfer an earlier map to the device to highlight what it should look like but it certainly shouldn't look like this!
Edit, Just to prove the difference, here is the x2 icon pack running on Navcore 8,010 with an earlier map installed to the same device (same location)
I did try re-sizing the icon with a 50% increase in size to see if it would take up more of the available area of the top left warning, this produced the same pathetic result - Mike
Steven0161
PostPosted: Wed Nov 12, 2008 12:20 am    Post subject: Reply with quote
I am glad it isn't just me I was wondering what I did wrong....any solution for the icons on stalks as they don't look quite right the stalk is slightly overlapping the image....damm tom tom Rolling Eyes
PostPosted: Wed Nov 12, 2008 12:26 am    Post subject: Reply with quote
The double icon image on the nav screen is actually correct on these screen shots as there are two Gatso cameras at the end of the road I was using for the pictures.
The pointy bit added to the POIicon is a mute point, you either love it or hate it - I guess those of us in the latter category will have to get used to it! - Mike
Steven0161
PostPosted: Wed Nov 12, 2008 12:30 am    Post subject: Reply with quote
well I am in the latter camp...I did have a trial of the TT camera version and the speed on stalks looked much smoother than the pocketgps ones. I hope some whizz comes up with a smoother set of icons and it does look naff Mad
PostPosted: Wed Nov 12, 2008 9:21 am    Post subject: Reply with quote
I've just tested our large icon set on a 520 running the latest update ands they work fine Confused
We'll have to perform further tests as it may be that the issue only affects x30's and perhaps x40's. I don't have an x30 device but will test on a 940 later.
sdm197
PostPosted: Wed Nov 12, 2008 9:29 am    Post subject: Reply with quote
Hi Darren,
Yes the large icons do work correctly, its just that they are much smaller (at least on the 930) although they do look smaller on your screen grab.
It looks like there is no cure for this, thanks for following up though,
SDM197.
PostPosted: Wed Nov 12, 2008 9:34 am    Post subject: Reply with quote
sdm197 wrote:
Hi Darren,
SDM197.
Do yours appear as per my screenshot above or as per MikeA's on the previous page? Is this a 930? you use?
PostPosted: Wed Nov 12, 2008 9:38 am    Post subject: Reply with quote
sdm197, what do you see on your 930, is it similar to either of the above pictures in my post? - Mike
PostPosted: Wed Nov 12, 2008 9:55 am    Post subject: Reply with quote
I had the 48x48 icon pack installed, when I loaded the 44x44 icons instead it all works again on the 930, so if the icons don't look quite right on your device check the icon x2 image size in pixels, if its not 44x44 download the correct set to your device from This Page - Mike
Anita
PostPosted: Wed Nov 12, 2008 10:31 am    Post subject: Reply with quote
Thanks, Mike. The 48x48 icons didn't work on my 720 either, but it's fine now I've change to the 44x44 set. Very Happy
Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21
PostPosted: Wed Nov 12, 2008 10:46 am    Post subject: Reply with quote
And I've now amended the compatibility table on the icons download page to show that 48 x 43 is not supported on v8 devices.
Anita
PostPosted: Wed Nov 12, 2008 11:11 am    Post subject: Reply with quote
Thumbs Up
Anita
UK map 1125.12264
Samsung Galaxy S21
Page 1 of 6
22.042 (10 Apr 24)
