Pocket GPS World :: View topic - Fortuna clip on not on TT3 list Help!
Jlam20
PostPosted: Tue Jun 01, 2004 9:21 pm    Post subject: Fortuna clip on not on TT3 list Help! Reply with quote
I have recently bought a TT3 Software and Fortuna Clip on. I uses a HP4150. I installed TT3 fine, Clip on have all the light lit, (Green light got GPS). But I don't know which driver I should be choosing on TT3. I have try almost all of them, but still nothing.
My bluetooth has established on connection fine, Just cannot understand why!!?? Please Help!!
J20 Embarassed
Privateer
PostPosted: Tue Jun 01, 2004 10:04 pm    Post subject: Reply with quote
Hi J20,
Using my Fortuna Clip-On Bluetooth GPS Receiver (in ST mode) with my 3970, I’ve used TT GPS Driver 3.0 with the following settings:
NMEA 0183v2 38400
Bluetooth Serial Port COM8:
As you’re using a 4150, your BT Serial Port is another COM, I think it is COM5 but you may have to experiment. If you’re using the Clip-On in XT mode then it’s different again. Thumbs Up
Robert.
Garmin Camper 770 LMT-D
sharky
PostPosted: Fri Jun 04, 2004 11:53 am    Post subject: Reply with quote
Hi J20
You should choose TomTom Wireless GPS. When you look in the GPS STATUS screen you can see the fix with satellites.
I had the problem that tehre was no connection because of the switch on the Clip-on was not quite in the XT-position. I switched it from ST to XT and after that it worked fine!
With regards,
Sharky
steved
PostPosted: Fri Jun 04, 2004 11:57 am    Post subject: Reply with quote
I have a Fortuna Clip on and an iPAQ4150 running TT3. The iPAQ is set to NMEA 0183v2 38400 and on Bluetooth serial port COM 6. This is with the Fortuna set to ST mode. I am using Tomtom GPS driver as I also run Memory Map
Steve
steved
PostPosted: Fri Jun 04, 2004 11:59 am    Post subject: Reply with quote
Whoops, that should be tomtom GPS driver 2.07....
selwonk
PostPosted: Tue Jun 22, 2004 2:08 pm    Post subject: Reply with quote
I thought the ClipOn had to be connected as a SirfTrak 38400?
22.044 (24 Apr 24)
