Pocket GPS World :: View topic - help with v8 map detail
rover220
PostPosted: Thu Oct 16, 2008 12:27 pm    Post subject: help with v8 map detail Reply with quote
hi guys.
im currently running a tomtom one v3 with v8 software and a 715 (i think) uk and europe map. i use it for my job hence this question really. its critical that canals/rivers are still on the map as i can be called out anywhere and need to be able to find certain spots where the road crosses said canal.
basically, if i post up some locations, would some kind soul post up screen shots so i can compare it to my current map so i can see if its worth upgrading?
cheers
mike
dhn
PostPosted: Thu Oct 16, 2008 1:02 pm    Post subject: Reply with quote
Can't assist with the canal location but tap the satellite bars on your unit and the next screen shows the version number of your firmware. Now, tap the version number and the next screen shows what map you have installed and the version (and build) number.
Do that and you will be sure what map you have installed.
carl_the_cobbler
PostPosted: Thu Oct 16, 2008 1:20 pm    Post subject: Reply with quote
If you want to PM them to me, or indeed get in touch through a PM and I will give you my email address, and have a look for you, otherwise just put them on here and I will look, I suppose I am saying I will have a look.
CHeers
Carl
rover220
PostPosted: Thu Oct 16, 2008 5:50 pm    Post subject: Reply with quote
here we go
all ive done is goto navigate to city centre and taken screen shot.
first up we have "hanley" (i have scrolled very slightly down and to the left to get some of the canal in)
now we have "great haywood" (no scrolling here)
and finally "fazeley" again, no scrolling
thanks very much for this Carl!
carl_the_cobbler
PostPosted: Thu Oct 16, 2008 6:34 pm    Post subject: Reply with quote
Right here goes, I have got a 920 with latest maps and software, just to keep you informed, hope this helps!!
Number 1 - Hanley
Number 2 - Great Haywood
Number 3 - Fazeley
Hope this helps, they all looked pretty similar to me.
If you need anything else, just say
Carl
rover220
PostPosted: Thu Oct 16, 2008 6:48 pm    Post subject: Reply with quote
brilliant, thank you Smile
gluey
PostPosted: Thu Oct 16, 2008 9:10 pm    Post subject: Reply with quote
Hi Rover 220,
Just a thought, If you are likely to have to return to these locations then why not set them up in a POI file for yourself.
Also while viewing the map select Show the co ordinates so you a fix for them.
Kev
PostPosted: Thu Oct 16, 2008 9:19 pm    Post subject: Reply with quote
rover220 wrote:
here we go
I've edited your images, forum rules are max 400 pixels wide for future reference Smile
rover220
PostPosted: Fri Oct 17, 2008 7:23 am    Post subject: Reply with quote
rover220 wrote:
here we go
oops sorry...wasnt aware of this.
mike
PostPosted: Sat Oct 18, 2008 1:51 am    Post subject: Reply with quote
Can I add a word of caution here....
The main issue with canals and water features is the amount of compression TomTom have to do to the map data to fit it on a specific device.
Comparing your maps in the One and someone else's on a 920 is not guaranteed to show you what you would get as an update for YOUR machine.
If you really want to make sure you'll need someone with a One....
22.034 (27 Mar 24)
