Pocket GPS World :: View topic - Speed Camera database download to my XDA
nod4584
PostPosted: Tue Mar 18, 2008 9:10 pm    Post subject: Speed Camera database download to my XDA Reply with quote
I have used all instructions to down load and deleted al ao files yet I cannot use the data base. Does not even show any cameras on route.
This way of downlading worked perfectly with pocket 6 version !! Any ideas please. Thanks
PostPosted: Tue Mar 18, 2008 9:59 pm    Post subject: Reply with quote
What software are you using?
PostPosted: Wed Mar 19, 2008 11:55 am    Post subject: Reply with quote
from the mention of 'ao' i'm guessing copilot 7?
when you restart cp7 do you get the progress bar saying it's updating pois etc? it can take a couple of minutes so it's not something you can miss easily!
if not then it may be worth checking it's in the correct map folder? do you have uk maps only or full europe? the guide was written on the assumption that it was european mapping (that's all i had at the time) and i don't know the equivalent folder names for uk mapping
PostPosted: Wed Mar 19, 2008 1:11 pm    Post subject: Reply with quote
Both myself and ''Oldie'' had to re-install the CP7 software from the CD to get this working on the XDA Orbit - 2, as supplied the device would start to update with the progress bar on the screen and lock up. As we live in completely different parts of the country it could be the pre-installed software on the supplied memory card is corupt - Mike
nod4584
PostPosted: Thu Mar 20, 2008 7:46 pm    Post subject: Reply with quote
Co Pilot 7. I have uninstalled it and reinstalled it from the PC and I and I have copied the csv files to XDA and deleted the ao files but it still wont show the cameras either statically or on route.
nod4584
PostPosted: Thu Mar 20, 2008 7:47 pm    Post subject: Reply with quote
I have the full european maps. Still doesn't work..!
nod4584
PostPosted: Thu Mar 20, 2008 7:50 pm    Post subject: Reply with quote
I have reinstalled the software from the CD and it still does not work..!
PostPosted: Thu Mar 20, 2008 8:34 pm    Post subject: Reply with quote
Did you also re-load the map from the disk as I had to? - Mike
nod4584
PostPosted: Thu Mar 20, 2008 9:31 pm    Post subject: Reply with quote
Yes I did. Another thing, when I copied the csv files to the xda they showed in the file on xda. But after opening CP7 I checked and they had then been deleted...! I am now really confused
PostPosted: Fri Mar 21, 2008 12:56 am    Post subject: Reply with quote
the csv files get 'converted' and added to the ao.... files (hence deleting the files before updating otherwise you would be adding data to the old ones!)
do you get the 'updating' message when you boot up?
morfis
PostPosted: Fri Mar 21, 2008 1:39 pm    Post subject: Reply with quote
Using two XDA Orbits here and have had no problems with the downloaded camera data.
What I did.......
Deleted AO*.* files from \Storage Card\COPILOT\EU\Save
extracted PGPSW files from downloaded archive and copied to:
re-started CP7 (and saw the 'updating' messages)
Went into CP7 POI settings and enabled POI Alerts. set the software up to display custom POIs
All works fine - no re-installation of software or maps needed on either of my Orbit's.
The inbuilt safety camera warnings won't work after doing it this way but I prefer the flexability of having separate POI files for camera types anyway.
22.034 (27 Mar 24)
