Ezy162 Occasional Visitor
Posted: Wed Aug 01, 2007 2:23 pm Post subject: |
okok chill the bean |
TheChef Occasional Visitor
Posted: Thu Sep 06, 2007 11:01 am Post subject: |
I have just had my PDA repaired, and had to re-install TTN5 back onto it, the camera database is in the folder Great Britain map on the SD card but they are not showing up on the Manage POI's so I can not tick them to make them active.
and my poiedit manager says the pocketgps is offine.
If the camera files are in the correct folder why won't they appear in manage POI's, ?
Was ok before it went off for repair. any advise would be greatly appreciated... |
Joined: 30/12/2002 17:36:20 Posts: 4912 Location: Oxfordshire, England, UK
Posted: Thu Sep 06, 2007 4:05 pm Post subject: |
Hi TheChef,
The POI Edit method had been stopped, to avoid confusion. Another way is now used to allow you to download the files.
You need to use this page instead.
Garmin Camper 770 LMT-D |
grumsta Occasional Visitor
Posted: Tue Sep 25, 2007 1:08 am Post subject: |
Hi just wondering if anyone has had any joy getting this to work with tomtom6 on a nokia 6120 classic? |
tuck1s Occasional Visitor
Posted: Tue Oct 02, 2007 7:36 pm Post subject: Automatic update with subscription |
Hi PocketGPSworld,
Along with probably quite a few other users, my PoiEdit sync recently stopped working, and after reading the forum, I've taken out my £19 subscription, and done a manual sync.
All looks fine, but I really miss the automatic sync that I had with PoiEdit. I am happy to pay my subscription, but I would like an automatic update method.
Are there any plans in the pipeline? surely it's not impossible for some client SW (like PoiEdit or something else) to provide credentials when downloading, that you are prepared to accept and validate?
[TomTom Navigator 5.2 running on Dell Axim X50] |
niek Occasional Visitor
Posted: Sun Oct 14, 2007 2:58 pm Post subject: download speed cams netherlands |
i don't get where I can download the speedcams for the netherlands.. can anybody give me a link.. |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10641 Location: Suffolk, UK
Posted: Sun Oct 14, 2007 3:35 pm Post subject: Re: download speed cams netherlands |
niek wrote: | i don't get where I can download the speedcams for the netherlands.. can anybody give me a link.. | You will need to Subscribe first and then Click the Speed Camera Link at the Top Left of every Page.
The Cameras for any European Country is combined into the EUR Download. _________________ Richard
peugeot306dturbo Occasional Visitor
Posted: Tue Oct 16, 2007 3:28 pm Post subject: If you're running out of POIs in TT5 |
Guys, got bored by the time I reached page 10 of this post so if this tip has been posted already I apologise:
I've run out of POIs (only 40 for TT5) on my Ipaq 2210. The solution to this for me was:
Use Speed zoned Gatso files (and set appropriate voice warnings)
Use Consolidated by Type files for everything else (due to the number of custom POIs I have this was best for me)
However you may also be able to fit the Speed zoned Mobiles if you have more room than me (which would be useful)
Simply delete the old speed zoned files which will not display as they won't fit (leaving the ones that will fit) and copy the Consol. by type ones across to the same folder. Then set the warnings as described in the other threads...
Eg:
[SZ] = Using files from Speed zoned db
[CL] = Using single files from Consolidated db
Say I have 27 Custom POIs (a lot I know)
I choose to use:
8 Gasos [SZ]
2 Mobiles [CL]
1 Redlight [CL]
1 Specs [CL]
1 Temporary [CL]
=13 POIs
27+13=40 (I have used my limit)
If I deleted some Custom POIs I didn't need, I might be able to fit some/all the Speed zoned Mobiles on there too (15 including 'P-Mobile' files)
I'm not an expert but I hope this helps. |
Posted: Tue Oct 16, 2007 3:39 pm Post subject: |
You are one over your limit as it is 39 for TTN5 - Mike |
FrequentFlyer Lifetime Member
Posted: Wed Oct 17, 2007 10:24 pm Post subject: |
Blimey...page 17.
Do I assume that I can download the camera files using TT Home...if so, struggling to find out how ! |
Hunterlaar Occasional Visitor
Posted: Mon Nov 26, 2007 6:05 am Post subject: |
If i enable the gatso poi alone on a nokia phone it disables all the other warning poi signs like redlights ect they don't show on the screen.. anyone know why this is? |
mburton2 Regular Visitor
Posted: Mon Jan 14, 2008 8:51 pm Post subject: |
I've just updated the TTN5.21 on my Dell Axim x51V (Mobile Windoz 5) to TTN 6.010...
Having just downloaded the UK speed camera DB (I now have only two "map" folders, Western&Central Europe, and EasternEurope...I copied the ov2&bmp files into Western&Central), I have a choice:
1) Enable the Various UK camera POIs (This works OK)
2) Connect my GlobalSat BT-338 GPs to the PDA (This works fine)
If I try to do both 1) & 2), the PDA just hangs/does nothing.
Anyone know why? |
Posted: Mon Jan 14, 2008 9:01 pm Post subject: |
Go to Change Preferences/ Enable_Disable POI and de-select the whole lot, use the warn when near POI funcion to get warnings - this might sort the issue out - Mike |
Posted: Mon Jan 14, 2008 9:47 pm Post subject: |
OK,Tried that....
Turned on the BT-GPS.....a few seconds later it connected to the PDA....then everything froze again.
EDIT
I noticed when de-selecting the "Warn when near", that some of the .bmps were red squares, and NOT the camera/speed icon I was expecting...a sign of a currupt download?? |
Posted: Tue Jan 15, 2008 7:38 am Post subject: |
mburton2 wrote: | EDIT
I noticed when de-selecting the "Warn when near", that some of the .bmps were red squares, and NOT the camera/speed icon I was expecting...a sign of a currupt download?? | The red square is an indication that a matching bmp file can't be found.
Either the name is wrong, it has to be an exact match to the ov2, or it doesn't exist in the Map Folder. _________________ Richard
