Pocket GPS World :: View topic - Deleting sound in CP
Oslo
PostPosted: Fri Mar 12, 2004 10:06 am    Post subject: Deleting sound in CP Reply with quote
By mistake, I put a warning sound on a McDonald's POI's. I'm not a McDonald-fan, so I do not need to be alerted by voice. Therefore I like to delete this sound, but when I get into the "First warning"-tab. there are no way to delete the "Sound to play as first warning" Rolling Eyes or?
DinAlt
PostPosted: Fri Mar 12, 2004 4:32 pm    Post subject: Reply with quote
If you don't want to be informed of Macdonalds you can either delete the overlay file from your PDA or if you still want to keep the overlay but don't want a warning click on the checkpoint icon, select overlay settings then highlight the overlay file for McD and select properties - first tab is detection - remove the tick in the "Detect PoI's from this overlay box" and it won't pick them up.
If your PDA isn't showing checkboxes do a soft reset first and this should make them appear. this should also allow you to clear the check box in the first warning section if you still want a visual notification of a McD but no voice.
Hope this helps,
DinAlt
Oslo
PostPosted: Fri Mar 12, 2004 4:44 pm    Post subject: Reply with quote
Thank you, DinAlt. But are there no way just to delete the Sound, and keep the CP POI pop-up? (McD is not important here, just used it as an example).
DinAlt
PostPosted: Fri Mar 12, 2004 11:53 pm    Post subject: Reply with quote
Hi again,
Just go to the properties section for the overlay you want and uncheck the boxes with first and last warning in them - ths will keep the pop up but will give no sound.
(I mentioned this at teh end of my last post).
DinAlt
Oslo
PostPosted: Fri Mar 12, 2004 11:57 pm    Post subject: Reply with quote
Thank you. I observed that after answering Embarassed
22.044 (24 Apr 24)
