Newsletter
Pocket GPS World :: View topic - Ash10's Voice Utility Software
Goto page Previous  1, 2, 3, 4, 5 ... 13, 14, 15  Next
anompi
PostPosted: Mon Apr 16, 2007 11:45 am    Post subject: Reply with quote
How to upgrade the volume of your Zumo/Nuvi TTS (Text To Speak) voice files to the highest level !!
The How to:
HowTo - Upgrade volume of Zumo TTS voices.pdf
As example i already have 3 TTS voices converted:
English -British-Emily - volume 75 to 99, version 1.43
Dutch-Claire - volume 80 to 99, version 1.43
French-EU-Virginie - volume 80 to 99, version 1.43
Place them in: GARMIN:\garmin\voice
Undo!!!
- Delete the English_British_Emily.vpm file from GARMIN:\garmin\gpx
- Disconnect your Zumo from computer and let it startup completly
- Reconnect your Zumo to your Computer
- Start Garmin Webupdater and let it check the software
- Check additional software in Webupdater
- Select the needed voice file (English British Emily)
- Press ok and the original Voice file is installed to your Zumo again.
(this is also working for deleted text or traffic file, not for maps!)
References:
[utl=http://zumoforums.com/zumo/viewtopic.php?t=1154]English Zumo board[/url]
Dutch GPS board
philpugh
PostPosted: Mon Apr 16, 2007 2:05 pm    Post subject: Reply with quote
Excellent - will be trying this tonight - the TTS voice (Emily) is just too quiet for high speed running.
Phil
philpugh
PostPosted: Tue Apr 17, 2007 9:33 am    Post subject: Reply with quote
Applied it to my system - works a charm. I will have to fine tune it as 99 seemes to give more distortion than I would prefer. At least the volume level is now comparable to Liz W's camera warnings.
Phil
anompi
PostPosted: Tue Apr 17, 2007 12:57 pm    Post subject: Reply with quote
Level 90 is good, 95 gives some distortion. In between i have not tested. Above 99 is not possible, numbers with 3 digits make the file unreadable by a Zumo.
highlander317
PostPosted: Sat Apr 21, 2007 7:44 am    Post subject: Reply with quote
how do you get this voice onto a c510? i tried but got nothing
11oydee
PostPosted: Sat Apr 21, 2007 10:54 am    Post subject: Reply with quote
Hi guy's.
I have an i3 with sd card but there is no voice directory just a poi directory.
Does this mean the voices are on the unit's internal memory & if so can I access them?
Ta.
11oydee.
Jamas
PostPosted: Sat Apr 21, 2007 11:54 am    Post subject: Reply with quote
In hexadecimal, there are plenty of other 2 digits numbers such as 9A to 9F, A0 to AF, B0 to BF, etc until FF.
99 is probably not the maximum!
Jamas
SP i3 S/W 2.9-> 2.7 City Navigator V8 NT+
Deviltronics
PostPosted: Mon May 07, 2007 3:52 pm    Post subject: Reply with quote
Not sure if this programme will allow me to do this, but can the files be modified and recorded in my own voice so I can use a completly different language (urdu/punjabi) to work on the garmins. I have a garmin nuvi 660.
I could then share this file with whoever wants this language. :D
The urdu language is available for the tomtoms but not for garmins. Sad
mussey1
PostPosted: Wed May 09, 2007 9:47 pm    Post subject: Reply with quote
Anyone know which 'bong' numbers are used for the speed alerts/overspeed.
I have changed the sound on all the 'bongs' and even deleted them on a number of occasions, but they still seem to remain on the system.
Can the 'bongs' be changed to 'spoken alerts'??
Thanks.
Mussey1.
philpugh
PostPosted: Thu May 10, 2007 5:50 pm    Post subject: Reply with quote
mussey1 wrote:
Thanks.
Mussey1.
This is possible with the non-TTS voices - try searching these forums - I saw it somwhere.
Phil
philpugh
PostPosted: Thu May 10, 2007 5:52 pm    Post subject: Reply with quote
Jamas
Interesting - I assumed that the figures were going to be percentage of maximum volume - haven't tried it as at 99 it's too distorted
Phil
Deviltronics
PostPosted: Sat May 12, 2007 4:46 pm    Post subject: Reply with quote
Sorry guys, but I haven't got a clue on how to get this to work.
When I run the voice utility programme, for the 'Garmin Voice File' I choose one of the .vpm files from my Nuvi.
But thats as far as I can get.
What exactly do I put in the 'Sound Files' box? I know it needs to a .wmv file but where do i get one from?
Once the .vpm is split will it show which file is for which speech, so when I update a single file I will be translating it correctly.
Please help.
sbarker
PostPosted: Sun May 13, 2007 6:21 pm    Post subject: Reply with quote
It's a nice piece of software.
Why does it need to access the internet so much when it is running ?
Ash10
PostPosted: Sun May 13, 2007 6:32 pm    Post subject: Reply with quote
When (and only when) you click on the "Join" button, it performs a quick check to see if there's a newer version available.
sbarker
PostPosted: Sun May 13, 2007 7:26 pm    Post subject: Reply with quote
I've modified all the non-verbal wav files (bongs and pings) in English_British and loaded them back onto my Zumo.
I've confirmed that they are loaded by using the Diagnostics function on the Zumo and played them back one at a time.
The "proximity alert sound" is still the same. Anyone got any suggestions ?
Page 4 of 15
20.065 (29 Jun 22)
Terms & Privacy
