Pocket GPS World :: View topic - Is Nuvi antenna-flipped-to-horizontal a MUST?
Sylar
PostPosted: Sun Jan 28, 2007 9:28 pm    Post subject: Is Nuvi antenna-flipped-to-horizontal a MUST? Reply with quote
Trying to decide between 360 and TT One. See Nuvis have chipset/antenna in tab that "must" be flipped to horizontal.
This is OK in cars, but must I also do it for pedestrian use?
Saw in another thread on satellite acquisition that Swing mentioned position of anenna tab.
If not obvious already, this will be my first GPS ever.
PostPosted: Sun Jan 28, 2007 9:41 pm    Post subject: Reply with quote
Welcome to the forum, The GPS aerial needs to be deployed to enable it, however you can use it when only slightly deployed, it certainly doesn't need to be at 90 deg to the body of the device - Mike
zogman
PostPosted: Mon Jan 29, 2007 10:11 am    Post subject: Reply with quote
the nuvi is a great bit of kit except for the gps aerial which spoils it...
swing
PostPosted: Mon Jan 29, 2007 4:08 pm    Post subject: Re: Is Nuvi antenna-flipped-to-horizontal a MUST? Reply with quote
Some people try to use the Nuvi with the antenna angled nearly vertically - this certainly isn't the best position for it, and horizontal is the best (given the aerial the best view of the whole sky), but it doesn't need to be perfectly level. Whilst walking it's probably not a problem at all, although something to be aware of.
cantgetlost
PostPosted: Mon Jan 29, 2007 4:26 pm    Post subject: Reply with quote
Walking around places like Paris I just stick the Nuvi in my shirt pocket with the aerial open( that normaly means vertical) when I need it. It seems to hold the signal quite well, other wise you end up waiting for it to find the satellites to know where it is.
Sylar
PostPosted: Fri Feb 02, 2007 10:32 pm    Post subject: Reply with quote
Great idea. I had been wondering about this point. I had better make sure unit fits my pocket, or take a suitable fanny-pack or belt-case to keep unit on. Of course, it probably will burn through battery in little time, I expect.
Have read elsewhere about turning backlighting off and so on to conserve power.
Thanks to all.
Lazily typed from the Florida Riviera...
80° 08' 13.66'' West, 25° 56' 19.80'' North
Nuvi 370 (when it arrives)
cantgetlost
PostPosted: Sat Feb 03, 2007 1:29 am    Post subject: Reply with quote
I get about 4 hours total with the backlight on and sound off when walking.
And just a note - "fanny" has a different meaning here Embarassed
More cat like Wink
swing
PostPosted: Sat Feb 03, 2007 11:44 am    Post subject: Reply with quote
Indeed - although the Nuvi 3x0 range are likely to fit easily in your shirt pocket, you may well find the 660 is way too big to fit.
22.034 (27 Mar 24)
