Pocket GPS World :: View topic - note for PGPSW support re- navman smartst desktop 2006
mostdom
PostPosted: Sun Jul 23, 2006 4:40 pm    Post subject: note for PGPSW support re- navman smartst desktop 2006 Reply with quote
navman smart desktop 2006 poi import program is no longer compatable with acs files. It no longer gives users a choice to find *.* files and will only list csv files. some posts are starting to appear on the forum regarding this issue.
Changing file from .acs to .csv solves problem.
Either additional poi download for new navman software should be made available or update the instalation guide.
Tim Buxton
PostPosted: Sun Jul 23, 2006 4:50 pm    Post subject: Reply with quote
The 2006 Desktop programme for the iCN530 is still compatible with .asc files. This might be an issue with the 7xx series, although I've been told by a Tech Support guy from Navman that .asc files are still compatible. Until I get hold of a 7xx myself, though, I won't be sure.
Tim
mostdom
PostPosted: Mon Jul 24, 2006 1:20 am    Post subject: Reply with quote
interesting, the acs files are compatable but only if you change the file extention from file.acs to file.csv, as I explained.
I upgraded from the old icn530 to the new icn750 where the 530 used to work but not with the 750's software.
When you use the open poi file in smart st select the extracted directory there are no shown files. when you go the change the file types it only gives you the csv option.
I have no issue with changing file extentions. But less pc savi users might not.
Thanks for the reply tim, at the least you know about it.
Tim Buxton
PostPosted: Mon Jul 24, 2006 8:45 pm    Post subject: Reply with quote
OK, there is another fix which doesn't involve the renaming of any files. It's true that the Navman POIEditor for the iCN7xx range defaults to look for .csv files and there is no way to change this in the dropdown Filetypes window. However, if you type *.* in the Filename window then you will see, unsurprisingly, all files! Double click on one of those listed .asc files and your POIEditor will recognise it immediately.
Tim
hln
PostPosted: Thu Aug 17, 2006 4:49 pm    Post subject: Navman compatabilty Reply with quote
I have tried your suggestion and tried the 'search button' but i cannot get my system an XP home edition to recognise the file to open it.
Is this still a ZIP file even after it has been opened?
If not, how can I get it to be read?
Tim Buxton
PostPosted: Thu Aug 17, 2006 9:46 pm    Post subject: Reply with quote
It is still a zipfile until after it is unzipped, even though Windows allows you to look inside the individual files. My laptop has XP Home on it and I can extract the files using Windows Explorer.
If you double click on the zipfile, don't you get the option to "Extract all files"?
Tim
nav-man
PostPosted: Mon Nov 20, 2006 2:35 pm    Post subject: Reply with quote
You can download Garman POI loader safety camera data base which is in csv format already and then upload it to your N20 works great.
Gee-Pee
PostPosted: Thu Nov 23, 2006 12:24 pm    Post subject: Reply with quote
Tried that and the 'coverted to csv' files from the Navman Consolidated download. As yet, after about 2 weeks of trying, I'm totally unsuccessful in getting any to work on my new N20 Crying or Very sad
Gee-Pee
tommo11
PostPosted: Mon Dec 18, 2006 10:31 am    Post subject: thanks very much Reply with quote
thank you for ur tip, the problem was fixed at once
thank you again
tommo11
Gilbo1973
PostPosted: Wed Feb 14, 2007 9:19 pm    Post subject: Reply with quote
I just got the ICN 720
Converting the files to CSV results in message from POI Editor of 'unknown file format'
It does not matter what I do the program gives the same message.
If I DON'T rename them and use the '*.*' method, it says 'unknown file format'
THIS IS DRIVING ME UP THE WALL
What am I doing wrong?
A NOOB question - when I download the files from this site, are they 'zip' files or not? Searching the forums has not enlightened me, but when they appear on my computer, they have NO file extension, and simply say 'file'. If they are compressed, what format are they supposed to be? Winzip tried - unsuccessful
Please help
Chris
Tim Buxton
PostPosted: Wed Feb 14, 2007 9:40 pm    Post subject: Reply with quote
YOU DO NOT NEED TO RENAME THEM, CONVERT THEM OR ANYTHING ELSE THEM. The Navman POIEditor can be forced to display .asc files by putting *.* in the File name box. They are in zip format and need to be unzipped first.
Tim
PostPosted: Thu Feb 15, 2007 11:30 am    Post subject: Reply with quote
...and if you are not seeing the .zip extension its probably because you have "Hide extensions for known file types" ticked in Windows Explorer Preferences.
In Win Explorer (or My Computer) go to the Tools Menu / Folder Options / View Tab, and untick it.
22.034 (27 Mar 24)
