Pocket GPS World :: View topic - HELP HELP please with installing destinator op software
slmmk1
PostPosted: Fri Sep 22, 2006 12:25 pm    Post subject: HELP HELP please with installing destinator op software Reply with quote
Hi everyone
My first post and i'm already stuck :-)
The SD card in my goodmans gnav10 has become damaged so i need to install the software onto a new card ive bought but cant figure out what i need to do. Ive got 2 cds (destinator op) and hae installed the destinator console but not sure what to do from there. PLEASE PLEASE someone heelp me througth this
many thanks
slmmk1
PostPosted: Mon Sep 25, 2006 5:59 pm    Post subject: Reply with quote
hi
does no one know how to copy the contents of an sd card containing destinator op onto another card and making sure it works?
thanks
allmen
PostPosted: Tue Sep 26, 2006 12:58 am    Post subject: Reply with quote
The easiest way would be to copy from the sd card onto the hard drive then back onto the new sd card or if you have a card reader, copy from whatever is using the card into the new card in the card reader. assuming it is connect to the pc and use the Microsft sync software. I use this for transfering from a PDA to another card.
Acer N35
Destinator 3
Destinator 6
slmmk1
PostPosted: Tue Sep 26, 2006 3:39 pm    Post subject: destinator problem Reply with quote
hi
ive tried that on a couple of sd cards now, it all seems to transfer over quite well but when i put it back into the goodmans gnav10 unit and load it up it says something like "the uk_ireland maps not found or are damaged..."
when i put the origianal card (even though its slightly damaged) it works fine
so i cant understand whats going wrong
allmen
PostPosted: Wed Sep 27, 2006 1:09 am    Post subject: Reply with quote
Have you tried to install direct from the Destinator console?
Acer N35
Destinator 3
Destinator 6
slmmk1
PostPosted: Thu Sep 28, 2006 4:27 pm    Post subject: Reply with quote
yes tried that too
but it seems to copy to the goodmans internal memory and wont copy to the sd card which ive pluged into the pc via usb reader.
allmen
PostPosted: Fri Sep 29, 2006 1:34 am    Post subject: Reply with quote
Have you tried to format the sd card? If you do try maske sure you format it with the correct FAT. which is FAT 16 I think but double check with someone before doing the format.
Acer N35
Destinator 3
Destinator 6
jimbo_hippo
PostPosted: Fri Sep 29, 2006 11:41 pm    Post subject: Reply with quote
I may be mistaken here but unless the software gives you the option (or you try chosing SD as target from the console and it lets you) it will automatically be on the device anyway. These cards that come with the software preinstalled simply run a .cab file (like a .exe file for mobile devices) and although you might think it runs from the SD it installs to the PDA and runs from there. In the WM2003 or WM5 there's a folder called 2557 on the SD which has the installers in it. Sometimes it deletes after install but try using file-explorer to run ALL the .cab files in there and see if it at least installs the application and addd maps later.
Windows Mobile 5 seems to always ask on install if you want to install to device or SD. But I don't know your OS. If it runs from device is that ok? Or is it not running from there?
In principle, if you just ignore the console and drag all files (check you have show hidden files active in Windows) to desktop then back again then it should work.
Why not try dragging all but the map files to the desktop, copy to new card then open Desti console with device connected via activesync and select SD as the target, install maps and all should be well.
Another alternative, go to C:\DestinatorApps\New Maps and copy the UK_ireland folder manually to the SD card then re-insert (i.e. not using the console).
I don't have this device and I know they work a little differently than my setup but thought I might share anyway. Feel free to correct me if it helps the original poster.
Tom Tom GO 720
Orange M3100, Orange SPV M5000
TomTom Navigator 6, Destinator 6
Holux GPSslim
jimbo_hippo
PostPosted: Fri Sep 29, 2006 11:43 pm    Post subject: Reply with quote
The above is a little confusing on reading it. So in short, do you have a folder called 2557 on your SD and if so, tell us what it has in it. That might be a good place to start.
Tom Tom GO 720
Holux GPSslim
22.034 (27 Mar 24)
