Pocket GPS World :: View topic - Tomtom Bluetooth GPS with MemoryMap Navigator
ryan_a
PostPosted: Thu Oct 02, 2003 4:22 pm    Post subject: Tomtom Bluetooth GPS with MemoryMap Navigator Reply with quote
Has anyone got any experience of getting the two working together? I tried for several frustrating hours yesterday on my iPAQ2210, but to no avail.
I think what ought to work is configuring Navigator to use COM8 and selecting NMEA as the GPS manufacturer at 38400 baud (although I did try 4800 as well), but every time I tried to connect I got the 'Cannot open COM port' error message.
Any ideas?
Many thanks in advance,
Ryan
PostPosted: Thu Oct 02, 2003 7:54 pm    Post subject: Reply with quote
NMEA 4800 will work on COM8. However, here's the cat amongst the pigeons. Have you upgraded to the latest TomTom GPS Driver ? v2.08 ?
If so, go into START | REMOVE PROGRAMS and remove the TomTom Bluetooth program near the top of the screen, you'll be asked to soft reset, and this will rectify it. This is a known problem, TomTom 2.08 will stop other GPS programs talking to the Bluetooth Receive port. We reported this as soon as TTN Driver 2.08 came out.
If you're not running GPS 2.08, then there shouldn't be any reason why you can't talk, try soft resetting the iPAQ, just in case TTN2 has locked open the port.
chapsworth
PostPosted: Fri Oct 03, 2003 11:13 am    Post subject: Thanks! Reply with quote
You guys are so helpful. Thanks.
I've been 'fannying' around trying to get my 2210/Memory Map/Globalsat to work. Most of the time it didn't, sometimes it did if I pressed an unknown sequence of keys.
I did what you suggested and everything worked within about 3 seconds!
Simon
PostPosted: Fri Oct 03, 2003 11:37 am    Post subject: Reply with quote
Excellent! I've reported this bug to TomTom three times now, to different contacts I have, but nothing back yet... :x
ryan_a
PostPosted: Thu Oct 09, 2003 2:21 pm    Post subject: Reply with quote
Thanks Dave - that's fixed it!
ryan_a
PostPosted: Thu Oct 09, 2003 2:29 pm    Post subject: Reply with quote
Another quick question - I've found a copy of the 2.07 driver; does this have the same stealing com port problem? I'm a bit concerned that without an updated driver, I'll end up not being able to switch my iPAQ on again if I don't shut down the bluetooth properly...
Thanks,
Ryan
PostPosted: Thu Oct 09, 2003 3:14 pm    Post subject: Reply with quote
Luckily no, the problem only became apparent in 2.08. We're going to soon start a download cache of all drivers issued from TomTom/Navman et all, and we will look at offering these on the download sectoin of the website in the near future.
tedkay
PostPosted: Sun Dec 28, 2003 11:34 am    Post subject: Memory Map v Tom Tom GPS Reply with quote
Hi Dave
I too experienced problems with Mem Map not being able to open the Com port after I updated the Tom Tom GPS Driver to 2.08. So when I saw that Tom Tom had released v2.09 I assumed that they (bearing in mind your repeatedly reporting the issue to them) would have fixed it.
Sadly that does not seem to be the case as exactly the same problem arose when I installed the update!
Your workaround is fine but I have to admit to being puzzled by it - if the GPS driver is removed from installed programs then how come I can still use the GPS?
Reagrds
Ted
PostPosted: Sun Dec 28, 2003 1:13 pm    Post subject: Reply with quote
Hi Ted, you're not actually removing the GPS driver. Basically prior to v2.08 when you installed TomTom Navigator 1 or 2, or an update you would have two programs that needed to be installed.
- TomTom Navigator Program/Update
- GPS Support Program/Update
Since GPS 2.08 what TomTom have done is add in a new program that appears in START | SETTINGS | REMOVE PROGRAMS called
- TomTom ~ GPS
If you remove the TomTom ~ GPS it won't actually remove the GPS Support Program, the TomTom ~ GPS basically is a fudged driver that powers on boot or power-on which tries to resolve the hanging problem with Bluetooth, which it does, but it then opens a huge bag of troubles for other apps.
DavidW
PostPosted: Sun Dec 28, 2003 5:45 pm    Post subject: Reply with quote
In fact, to totally get rid of TomTom GPS 2.08 or 2.09, you uninstall "TomTom ~ GPS" a second time. It appears that the first uninstall, which mandates a soft reset, seemingly removes the inteference with the Bluetooth stack (I can't check this as I don't have a Bluetooth GPS).
The second uninstall really uninstalls the program (with 2.09, you're forced to soft reset again afterwards, though not with 2.08 ).
DavidW
PostPosted: Sun Dec 28, 2003 5:57 pm    Post subject: Reply with quote
Drat - the one time I don't preview, I fall over the 8) is interpreted as a smiley issue, and I didn't realise I needed to turn smileys off. I can't edit the post now, but where the smiley is in that last post should be 2.08)
David :( (smileys deliberately off in this post)
22.034 (27 Mar 24)
