Pocket GPS World :: View topic - Distance From POI
Distance From POI
JohnF
PostPosted: Sun Jan 08, 2006 10:35 am    Post subject: Distance From POI Reply with quote
When I am out on the road & look up a POI, I always get them listed & and and the distance measured from my home location. Can this be changed to the current position?
Using 5.21.
Regards John
Tim Buxton
PostPosted: Sun Jan 08, 2006 1:37 pm    Post subject: Reply with quote
If you have a fix, the distances (as the crow flies) should be from your current location.
Tim
andy-c1
PostPosted: Sun Jan 08, 2006 2:30 pm    Post subject: Reply with quote
no i don't think there is ,but once you get a fix you can then look up a poi and then they will be from that point
TomTom 5001
JohnF
PostPosted: Sun Jan 08, 2006 6:54 pm    Post subject: Reply with quote
Thanks, Just tried it again and it works ok now. Perhaps I did not have a fix at the time I tried it on the road. I was trying to find a restaurant and I could only get those near my home. Most frustrtating.
Regards John
Nexus 5, Ipod Touch 4G and iPAQ h2210 TomTom Navigator 6.75
Regards John
argosafe
PostPosted: Mon Jan 09, 2006 11:23 am    Post subject: Reply with quote
You can also see more POI's than those near to your location (or from home if you are using A-B planning without a fix) by tapping on the keyboard symbol which appears when the nearest particular POI's you require are listed.
Eg, you use Navigate to, then POI, then (for example) Restaurant. This then lists those near to home or your GPS position.
Now tap the Keyboard symbol in the lower left corner of that screen and you will be able to put the whole or part of another Restaurant name you are looking for. This then lists more relevant POI's.
XDA Orbit (the best so far)
XDA 2S
IPAQ 5455
IPAQ 4700
Globalsat Bt 338
Globalsat 337 CF reciever
Navman sleeve
256Mb Kingston CF Card
Lexar 512Mb card
Toshiba 1Gb SD card
JohnF
PostPosted: Tue Jan 10, 2006 12:07 pm    Post subject: Reply with quote
Thanks for that info. I have also found it's easy to change the Home location to the cursur postition ( save home in favorites fist to reset it afterwards) then all the POI's work from your current (ie new home) location. Useful in a city when you know where you are but are looking for a POI.
argosafe
PostPosted: Tue Jan 10, 2006 5:11 pm    Post subject: Reply with quote
Good idea re changing home location.
thanks!
XDA 2S
IPAQ 5455
IPAQ 4700
Globalsat Bt 338
Navman sleeve
Lexar 512Mb card
Toshiba 1Gb SD card
22.043 (17 Apr 24)
