Pocket GPS World :: View topic - Gizmondo Navigator 2006 Powered by CoPilot Help...
julz
PostPosted: Thu Dec 29, 2005 2:45 pm    Post subject: Gizmondo Navigator 2006 Powered by CoPilot Help... Reply with quote
Hi Guys,
Don't know if anyone can help me, but I got a Gizmondo for xmas, and it has sat nav on there, which is by CoPilot. I want to download the camera database onto it, but from reading the instructions on here, I need CoPilot on my PC, which I don't have.
Does anyone know if I can dowload the camera onto my gizmondo any other way?
Julz
alix776
PostPosted: Thu Dec 29, 2005 2:56 pm    Post subject: Reply with quote
if you have copilot 6 then just copy and paste the ov2 files to the the save folder on the gizmoid i know alk do uodate the database with i direct down load its the poi.dat file you replaec have look at the alk site www.alk.eu in the support pages as well if you if its not cpilot 6 then it will be copilot 5
device Lumia 950 xl
julz
PostPosted: Thu Dec 29, 2005 3:15 pm    Post subject: Reply with quote
Cheers,
so I've been here....
http://support.alk.eu.com/cgi-bin/alk.cfg/php/enduser/std_adp.php?p_faqid=326&p_created=1130514866
And downloaded and saved this to my giz in the 'save' folder, is that all I need to do, or do I need to download from here the ov2 file as well?
Cheers for the help
Julz
:D
alix776
PostPosted: Thu Dec 29, 2005 3:23 pm    Post subject: Reply with quote
no all you need to do is download the poi.dat copy it across to the save folder make sure it set to overwrite the current file though
device Lumia 950 xl
julz
PostPosted: Fri Dec 30, 2005 10:51 am    Post subject: Reply with quote
Oh pants...i've already downloaded and copied them all across Sad
Oh well....i'll have to give it ago soon and see if it works or not.
Thanks for your help...it's been great
Julz
:D
PONDEROUS
PostPosted: Sat Dec 31, 2005 2:07 pm    Post subject: Reply with quote
Just in case anyone other than Julz reads the above, Julz and Alix776 are discussing to two discrete methods of updating Copilot 6 POIs, the co-existence of which has led to some misunderstanding.
Copilot 6 includes a "new" POI import method not seen in CP 5 (actually, it is a method used by some other navigation packages). The "old" method has not been discontinued.
The "new method utilises OV2 files, which can be downloaded from third party sources such as the appropriate pages of this forum. The "old" method utilises the POI.dat file, which is the Copilot "in-house" POI file.
Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005
julz
PostPosted: Fri Feb 03, 2006 9:30 am    Post subject: Reply with quote
I know it's a bit delayed,but i've been using my Giz, and the speed camera POI's aren't working...they're definately set to show them, but they don't show up, and no warning is spoken....is this because I copied all of the files across and should have only copied the 1 file...
Can i reset this? Or can anyone help?
Julz
PostPosted: Sun Feb 05, 2006 11:41 am    Post subject: Reply with quote
Providing you follow the instructions (to the letter) here then you will not have any problem.
julz
PostPosted: Wed Apr 26, 2006 7:39 am    Post subject: Reply with quote
Me again...
I know it's a bit delayed, but does anyone know if there will be an update other than November 2005 for the Giz now that they have gone bust?
Also, where can I get a European map?
Julz
desertdog
PostPosted: Fri Jun 09, 2006 5:37 pm    Post subject: Reply with quote
Excellent guide to camera downloads - thanks Dave!
Up and running in 10 minutes
Is there a way to tie in voice alerts for camera positions on the Gizmondo?
Des
GrimBeard
PostPosted: Sat Jun 10, 2006 9:51 pm    Post subject: Reply with quote
Blimey, Dave Burrows "The Management" does exist. You got Lord Lucan working at ALK as well?
I've been dealing with one of your agents, PM me for his name, trying to get a managerial response to a complaint I have about an upgrade to CP6, the process, pricing and just about everything else.
It’s like nailing jelly to the ceiling. The gatekeepers (Agents!) just will not let me past.
GB
PS Still, just, a CP5 customer, only because I can’t find anything better!!
PPS Sorry for hijacking your post, ban me if you want, couldn't care less.
22.043 (17 Apr 24)
