Pocket GPS World :: View topic - EasyDevices Launch the latest GlobalSat SiRF III receivers
PostPosted: Fri Sep 02, 2005 8:04 pm    Post subject: EasyDevices Launch the latest GlobalSat SiRF III receivers Reply with quote
The GlobalSat UK Distributor brings the latest GlobalSat SiRF III wired GPS receivers to the UK Marketplace.
GlobalSat have produced a pair of receivers with the new SiRF III chipsets, with different cable configurations to suit just about any wired GPS application.
At PocketGPSWorld.com we are putting both the devices through their paces. Darren has the USB version the BU-353 whilst I am looking at the normal cabled version the BR-355.
I remember being very enthusiastic about the original GlobalSat wired receiver the BR-305, but these new devices are an order of magnitude better. Our reviews will be available in the near future.
We received the following Press Release from EasyDevices today:
EasyDevices Press Release wrote:
EasyDevices go all the way with new SirfStar III rollout
The Products
EasyDevices.co.uk, the UK distributor for Taiwan-based Globalsat Technology have now launched two new SirfStar III GPS products into the UK marketplace. The two GPS receivers are named as the BR355 (a GPS mouse for connection to PDA) and the BU353 (USB GPS Mouse for connection to desktop or laptop).
These will be the first wired GPS receivers in the UK to use the new Sirf Star III chipset.
With small, and very stylish design, the BR355 and BU353 are an impressive addition to the company’s portfolio of GPS receivers.
Already a market-leader, Globalsat are continuously developing their product range to suit the changing needs of the consumer, through ongoing research & development. This product is just another example of how quickly this company can do that.
Hot on the tail of their BT338, an impressive Bluetooth receiver that has taken the market by storm, the new receivers are expected to have an equally enthusiastic reception.
The Manufacturer
Globalsat are a Taiwan based company with ISO 9001: 2000 certification. This accreditation re-affirms Globalsat’s position as a quality GPS manufacturer. www.globalsat.com.tw
The Launch Date
September 2005.
UK Distributor
The Globalsat BR355 and BU353 can be purchased through the official UK distributor www.easydevices.co.uk.
EasyDevices.co.uk are a UK-based Distributor and Reseller of Pocket PCs, GPS Solutions and PDA Accessories.
Both devices have similar specifications. Below is an extract from the www.GlobalSat.com.tw website:
GlobalSat Specifications wrote:
Products Name: GPS Receiver
Products no.: BR-355
The BR-355 GPS Receiver can be utilized in a variety of applications that require a magnetic mounting with waterproof configuration. With non-slip on the bottom and the special compact design, the BR-355 is completely self-contained and waterproof. It incorporating the latest SiRF Star III GPS chipset and an active patch antenna so you receive a high degree of GPS accuracy.
Typical application can include marine environments, aviation, commercial use such as fire truck, police cars and utility vehicles and buses. The extended 5 feet long cable allows for easy routing to your PC behind headliners and side panels and terminates to a custom PS/2 connector for interfacing with one of the available cable kits that is purchased separately.
Features:
1. SiRF Star III High Performance GPS chipset
2. High sensitivity (Tracking Sensitivity: -159 dBm)
3. Extremely fast TTFF (Time To First Fix) at low signal level
4. Support NMEA 0183 data protocol
5. Built-in SuperCap to reserve system data for rapid satellite acquisition
6. Built-in patch antenna.
7. Super-cohesive magnetic for mounting on the car
8. RS232 interface connection port.
9. Waterproof and non-slip on the bottom.
10. LED indicator for GPS fix or not fix.
LED OFF: Receiver switch off
LED ON: No fix, signal searching
LED Flashing: Position fixed
11. WAAS ENGOS is supported.
Specification:
Chipset: SiRF Star III
Frequency: L1, 1575.42 MHz
C/A code: 1.023 MHz chip rate
Channels: 20 channel all-in-view tracking
Accuracy Position: 10 meters, 2D RMS
5 meters, 2D RMS, WAAS enabled
Velocity: 0.1 m/s
Time: 1us synchronized to GPS time
Datum
Default: WGS-84Acquisition
Time
Reacquisition: 0.1 sec., average
Hot start: 1 sec., average
Warm start: 38 sec., average
Cold start: 42 sec., average
Dynamic Conditions
Altitude: 18,000 meters (60,000 feet) max
Velocity: 515 meters /second (1000 knots) max
Acceleration: Less than 4g
Jerk: 20m/sec × 3
Power
Main power input: 4.5V ~ 6.5V DC input
Power consumption: 80mA
Protocol Electrical level: TTL level,
Output voltage level: 0V~2.85V
Baud rate: 4,800 bps
Output message: NMEA 0183 GGA, GSA, GSV, RMC, VTG, GLL
Physical Characteristics
Dimension: 53mm diameter, 19.2mm height
Cable length: 1.5 meters
Operating temperature: -40°C to +85°C
uffe73
PostPosted: Sat Sep 03, 2005 12:57 pm    Post subject: Reply with quote
I'm looking forward to reading this review!
I was just wondering if the cable connector is the only difference between BR-355 and BU-353. I would guess that most users, just like me, want the option of connecting their GPS receiver to both PDA and laptop depending on the situation. Being forced to buy TWO separate GPS receivers seems like a very unflexible solution.
The Holux GR-213 Mouse Receiver has a mini-DIN connector and can be connected to either PDA or USB depending on which adaptor cable you buy. Very handy!
It would be very interesting to see a comparing test between these new Globalsat receivers and the GR-213. Maybe there are more mouse receivers with SiRF III to be included as well. I've read about a device called iTrek S3, but I don't know if it's out yet.
Best regards,
Ulf
TomTom GO720T: App ver 8.351(9982/090518), OS:315187, GPS v1.20, Boot 5.5120
TT RDS-TMC: 4V00.013
Maps: Scandinavia v840.2562, Western_Europe v715.1703
Garmin GPSMap 60CSx (SW ver. 3.70)
johnmar
PostPosted: Sat Sep 03, 2005 2:57 pm    Post subject: Reply with quote
Hi Ulf
I think you will find that the iTrek S3 is a re-badged BR35*
http://www.semsons.com/is3usbgpsres.html
How are you getting on with your GR-213? I am very impreseed with mine
Regards
John
iPAQ3830 (32MB) PPC2002 ROM 1.20
CF Expansion Pack
Holux GR-213 GPS Mouse (GSW3.1.1 -3.1.00.07 C23B1.00)
Kingston Elite Pro 1 GB CF Card for maps
Viking 512MB SD Card (not used for navigating)
TTNav 5.210 (5430) Maps of W Europe
uffe73
PostPosted: Sun Sep 04, 2005 7:04 pm    Post subject: Reply with quote
Except for the issues I've described in this thread I'm very pleased with it. The downsides I've discovered seem to be more related to the limitations in the current SiRF FW than the GPS reciever itself. As regards to EGNOS the safest thing would probably bee to wait until next year (when EGNOS has been officially released) before trusting the SiRF implementations...
Ulf
EasyD2
PostPosted: Mon Sep 05, 2005 10:44 am    Post subject: Reply with quote
Hi uffe73,
With the BR355 receiver (which has a PS2 type connection) you can request a cable to convert it to USB. So effectively, you can have 1x cable for your PDA and 1x cable for your laptop if you intend to do GPS on both devices.
Tel: 0871 7000 156
Globalsat UK Distributor
JSW
PostPosted: Mon Sep 12, 2005 12:20 am    Post subject: Reply with quote
OK, am I missing something? How can a PS2 port be connected to a Pocket PC, i.e. how is the BR355 actually connected?
PostPosted: Mon Sep 12, 2005 8:45 am    Post subject: Reply with quote
It is not the PS2 port that connects to the PPC, but a set of cables allowing the different PPC connectors to interface to the GPS through a PS2 connector
