Pocket GPS World :: View topic - TTG Startup Splash Screen
RB
PostPosted: Sat May 07, 2005 11:39 am    Post subject: TTG Startup Splash Screen Reply with quote
dunno it this has been spoke about before, i did a search but couldn't find anything.
there is a splash.bmp file in the root directory on the TTG SD Card, a picture of a green hand touching a color TTG that shows when you start up your TTG, well this can be changed for your own picture, maybe of your family, car info of your car(incase your TTG is stolen) or whatever.
i've seen other sites that have ready made pics for you to use but it can be any aslong as it a 240x320 24bit .bmp file and you name it splash.bmp
when you look at your picture it's on it's side ie 240 wide 320 high but the TTG will rotate it, have a look at the splash.bmp file you already have on your card and you'll understand, or take a look at the file i've used
Image hosted by Photobucket.com
Skywalker
PostPosted: Sat May 07, 2005 9:43 pm    Post subject: Splash bmp Reply with quote
This is the only thing that has eluded me. I cant even find the original splash screen. Could you possibly post simple step by step instructions on how to do this.
Many Thanks
sgould
PostPosted: Sat May 07, 2005 11:32 pm    Post subject: Reply with quote
Instructions are as simple as he said above.
Make a picture 320 x 240 pixels. Save it as .bmp (24 bit). Turn it sideways. Call it splash.bmp and drag it to the GO.
hypnos
PostPosted: Sat May 07, 2005 11:47 pm    Post subject: Reply with quote
like skywalker above, I have the image ready and the right size,240wide by 320 high, but i can not find any "splash.bmp" in the TTG to change, Crying or Very sad
Wishlist
PostPosted: Sat May 07, 2005 11:49 pm    Post subject: Reply with quote
Its in the root
hypnos
PostPosted: Sat May 07, 2005 11:53 pm    Post subject: Reply with quote
just tried again, and it is all sorted...so thanks for all the help, I can see me now making pictures all night...thanks again
RB
PostPosted: Sat May 07, 2005 11:55 pm    Post subject: Reply with quote
when you plug your GO into the usb and access the SD Card or plug the SD Card in a card reader the splash.bmp will should be in the root directory ie the first part you come to and not in any of the folders.
i'm not sure if the splash.bmp is on the TTG before the v5.00 update as i never had one then can anyone comfirm if it is or not as this might be why Skywalker can't find it.
Who is General Failure and why is he reading my Hard Drive????
hypnos
PostPosted: Sun May 08, 2005 12:02 am    Post subject: Reply with quote
just to add my bit again, i never found the "splash.bmp" in the TTG either, I just dragged the new picture in, switched it off and back on, and there it was, and it turned it the right way round for me.
:D
PostPosted: Sun May 08, 2005 7:56 am    Post subject: Reply with quote
Yes there wasa splash screen, but it wasn't called splash.bmp.
It was mentioned here.
22.034 (27 Mar 24)
