Pocket GPS World :: View topic - I can see the sea
I can see the sea
dai_uk
PostPosted: Wed May 04, 2005 9:04 pm    Post subject: I can see the sea Reply with quote
When I first got my new toy I was poking about with it while driving (I know I know) and got the above sea level data come up, never been able to find it again anybody any ideas
Scruge
PostPosted: Thu May 05, 2005 2:05 am    Post subject: Reply with quote
What do you mean by sea level data? According to Navman the 510 doesn't provide elevation.
dai_uk
PostPosted: Thu May 05, 2005 3:17 pm    Post subject: Reply with quote
Well mine did........once. bottom of screen above the dark blue address bar, the lower L/H side was filled with lighter blue background with height above sea level data in white lettering. But as I say not been able to find it again.
Scruge
PostPosted: Thu May 05, 2005 3:31 pm    Post subject: Reply with quote
Perhaps they removed it with one of the updates. The area on the display you refer to is near the GPS single strength indicator, isn't it?
Scruge
PostPosted: Sat May 07, 2005 2:46 pm    Post subject: Reply with quote
BTW, I noticed if you goto one of the gps status screens (3rd I believe) you'll find the elevation in bottom right hand corner in very tiny print along with other info. Strange being Navman support said the 510 doesn't provide elevation. My firmware version is 3.0027 incase you don't find it on yours.
sealion
PostPosted: Sat May 07, 2005 3:47 pm    Post subject: Reply with quote
No, surely that is the elevation of the satellite highlighted. If you change satellite so does the elevation.
Scruge
PostPosted: Sat May 07, 2005 5:16 pm    Post subject: Reply with quote
I'm pretty sure its your elevation. Mine is consistant with my hand held gps. I typically see a variation depending on satellites of between 65'-91' and according to data from usgs my actual is 76' above sea level.
My understand is that elevation is a bit more tricky to calculate and requires a minimum of 4 strong satellite signals.
But then again I haven't come across any documentation regarding the info displayed either.
sealion
PostPosted: Sun May 08, 2005 3:29 pm    Post subject: Reply with quote
I say again, if you move the highlight from one satellite to the next, so does the elevation. This indicates the angle of elevation above the horizon. It does not give your elevation above sea level.
Simon1
PostPosted: Sun May 08, 2005 8:20 pm    Post subject: Reply with quote
I can confirm sealion's comment. Definately the satellite's elevation.
Scruge
PostPosted: Mon May 09, 2005 3:27 am    Post subject: Reply with quote
yep, looks like you're right... Knew it was to good to be true.
So what purpose is served knowing the azimuth and elevation of a satellite with only two significant digits?
21.094 (27 Sep 23)
