Pocket GPS World :: View topic - One Easy Port Mount to Brodit conversion
PostPosted: Fri May 14, 2010 11:39 pm    Post subject: One Easy Port Mount to Brodit conversion Reply with quote
First off you will need a Pro-Clip to suit your vehicle, there are loads to choose from, and the Brodit TomTom Ball which, in this case was salvaged from an x40 Brodit Mount, but a Brodit/ TomTom style ball is now available under the part number of 533091 directly from Brodit/ ProClip, here the Brodit "Ball" is attached to the Pro-Clip sat next to the standard Easy Port windscreen mount:
Look above the hinge line and you will see two small rubber plugs, these need to be removed (they simply flick out using your finger nails) to reveal two Philips head screws:
Remove the two screws and the mount comes apart very easily:
Place the old windscreen sucker part to one side and re-assemble the ring portion of the Easy-Port mount to the Brodit Ball by trapping the ball between the easy port ring and top cap, secure in to position using the two screws, these only need to be nipped up do not over tighten:
The Pro-Clip plus the Easy-Port secured in to my car (Ovlov V70), the Brodit Pro-Clip simply clips over the airvent securing to the structure either side of the vent to provide a solid mount for the navigation device, no holes are needed and if removed no traces of it being fitted are left in the car:
Finally, what does it look like with the device attached
If you want the device higher up rotate the entire mounting ring through 180 degrees and the device sits 75MM (3") higher:
No real reason for posting this other than to highlight what is possible should you own a device that uses the Easy Port mount and you don't like windscreen suckers - Mike
22.044 (24 Apr 24)
