lightbox61 Occasional Visitor
Posted: Tue Mar 21, 2017 7:30 pm Post subject: DriveAssist50 Voice Commands? |
I have inheritted a Garmin Drive assist 50 and wondered if anyone might be able to help.
I can use the voice commands to find favourites, home, categories and history but can't work out how to do the basics - drive to an address and drive to a city centre!
Please can someone tell me how I do this.
Many thanks |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4456 Location: West Sussex
Posted: Tue Mar 21, 2017 7:54 pm Post subject: |
You can't, at least not directly. You can navigate to favourites and history though, so just ensure any destinations are in favourites.
Having said that the instructions say you should be able to say Find place, and then input city or postcode. So far I've never got that to work and it's not in the list of phrases in the Voice Control app. _________________ Where there's a will ... there's a way.
walkerx Lifetime Member
Joined: Oct 21, 2009 Posts: 491 Location: South Yorkshire
Posted: Tue Mar 21, 2017 7:55 pm Post subject: Re: DriveAssist50 Voice Commands? |
lightbox61 wrote: | I have inheritted a Garmin Drive assist 50 and wondered if anyone might be able to help.
Many thanks |
when you say voice command, you get a list of the available commands you can use - when you say an address it will list what it thinks you said and you choose the right option |
Posted: Tue Mar 21, 2017 8:00 pm Post subject: |
sussamb wrote: | You can't, at least not directly. You can navigate to favourites and history though, so just ensure any destinations are in favourites.
Having said that the instructions say you should be able to say Find place, and then input city or postcode. So far I've never got that to work and it's not in the list of phrases in the Voice Control app. |
Thanks for the replies - although they seem to be slightly contradictory!
That's exactly what I was trying to do - on my tomtom it is very straightforward - I just say "drive to a city centre" and then name the city or drive to an address and then say the address.
When I say " find place" nothing happens! |
Posted: Tue Mar 21, 2017 8:10 pm Post subject: |
That's my experience too, find place does nothing
Edit: Just discovered why, the Drive models have two options, Voice Command and Voice Control (confusing!). I guess it depends on the model but my DriveAssist has Voice control (Find place doesn't work) but if you have Voice Command it should. Voice Control seems far simpler and less able than Voice Command, which I suspect is on the more expensive models in the Drive series, or could be map related as something I've just seen indicates Voice Command may only be available with the full EU map (I just have Western Europe on mine). _________________ Where there's a will ... there's a way. |
Posted: Tue Mar 21, 2017 8:40 pm Post subject: |
sussamb wrote: | That's my experience too, find place does nothing
Edit: Just discovered why, the Drive models have two options, Voice Command and Voice Control (confusing!). I guess it depends on the model but my DriveAssist has Voice control (Find place doesn't work) but if you have Voice Command it should. Voice Control seems far simpler and less able than Voice Command, which I suspect is on the more expensive models in the Drive series, or could be map related as something I've just seen indicates Voice Command may only be available with the full EU map (I just have Western Europe on mine). |
Mine's western europe too. That is most bizarre, please may I ask where the heck you found the info as even google isn't too helpful on this! |
Posted: Tue Mar 21, 2017 9:06 pm Post subject: |
It's in the manual _________________ Where there's a will ... there's a way. |
Posted: Tue Mar 21, 2017 9:18 pm Post subject: |
sussamb wrote: | It's in the manual |
Hahaha, who on earth would think to look in the manual?! |
M8TJT The Other Tired Old Man
Posted: Wed Mar 22, 2017 12:21 am Post subject: |
There is even an emoticon for that that sussamb chose not to use being a generous chappie. It goes a bit like this this
Kremmen Pocket GPS Verifier
Posted: Wed Mar 22, 2017 6:53 am Post subject: |
Voice command v Voice control
That's ringing bells.
That Drive unit I had briefly last year had the system where you don't shout verbal commands but menu numbers. Sort of like these telephone systems.
"One" then it displays the one sub menu, then you decide from that which item or another sub menu you want by shouting the menu number at it.
As I've posted before, I could not get it to distinguish between 2 and 3 then 4 and 5. It kept telling me that my command was too close to another one. _________________ Satnav:
Car Average MPG :
