Pocket GPS World :: View topic - Basecamp store maps on PC?
pcaouolte
PostPosted: Fri Jan 20, 2017 7:06 pm    Post subject: Basecamp store maps on PC? Reply with quote
Playing with Basecamp. When my Garmin device is plugged into the PC I can see the maps on the device and select the one I want to use in Basecamp. Basecamp says that the map is installed on the PC and asks if I want to use the one installed on the PC. This works ok until I disconnect the Garmin device, with the Garmin device disconnected I cannot select the map in Basecamp. If the map is installed on the PC why do I need the device connected to see it? Is this how it works or am I missing something?
Paul
PostPosted: Fri Jan 20, 2017 7:13 pm    Post subject: Reply with quote
In Garmin Express, bottom of home page, where does it say the PC maps are saved to, and, are they there ?
Satnav:
Car Average MPG :
pcaouolte
PostPosted: Fri Jan 20, 2017 7:20 pm    Post subject: Reply with quote
It said they were installed to C:\ProgramData\Garmin\Maps but that folder was empty. Tried the install again and can see them in Basecamp now. Thank you for pointing me in the right direction.
Paul
PostPosted: Fri Jan 20, 2017 7:55 pm    Post subject: Reply with quote
I don't know whether Garmin have fixed it but keep an eye on that folder.
I've only got a small SSD as my C:\ and I wondered why it was filling up. Turned out to be the last 3 map updates and umpteen firmware updates which at multi Gb soon filled it.
I've now pointed my maps to my multi Tb D: drive.
Satnav:
Car Average MPG :
pcaouolte
PostPosted: Sat Jan 21, 2017 11:07 am    Post subject: Reply with quote
Will keep an eye on it, thank you.
Paul
dales
PostPosted: Sat Jan 21, 2017 11:15 am    Post subject: Reply with quote
...and also watch ProgramData\Garnin\CoreService.
Dales.
pcaouolte
PostPosted: Sat Jan 21, 2017 11:21 am    Post subject: Reply with quote
C:\ProgramData\Garmin\Maps is 4.73Gb after one map update.
C:\ProgramData\Garmin\Coreservice is 10.2Gb after one set of firmware updates.
Is it safe to delete this stuff?
Paul
PostPosted: Sat Jan 21, 2017 11:24 am    Post subject: Reply with quote
CoreService yes, Maps no as that's the map that BaseCamp uses.
PostPosted: Sat Jan 21, 2017 2:30 pm    Post subject: Reply with quote
I've just removed a load of stuff from \Coreservice\
Even though my Basecamp maps go to my D:\ drive there was still 8Gb on my C:\
Deleted the last 6 firmware updates in there as well as Mb's of related stuff in the temp folder.
Ta for that link
Satnav:
Car Average MPG :
22.043 (17 Apr 24)
