| Author |
M8TJT The Other Tired Old Man
Joined: Apr 04, 2006 Posts: 4838 Location: East Sussex, UK
Posted: Sun May 06, 2012 2:17 pm Post subject: |
| Sounds reasonable to me as well, as it's subcategories that screwed up in this instance |
| Back to top |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10203 Location: Suffolk, UK
Posted: Sun May 06, 2012 3:24 pm Post subject: |
| EGLITTLE wrote: | | Perhaps it would be better to change note 3 to read SUB categories ... |
This cropped last week with another user, and is on the 'to do' list.
If you do need to have more than 20 Subcategories, then there are 2 options:
1: Download more than 1 OV2 File and use POIEdit to append the files.
2: Download as a single CSV, or ASC, file as use MakeOV2 to convert the text file.
#2 is quicker, once the MakeOV2.exe is available, as you can simply drag the text file to MakeOV2 for the conversion to be almost instant. _________________ Richard
TT 910 V7.903 (9183/081205) OS:2344
Europe version 910.4895 |
| Back to top |
EGLITTLE Occasional Visitor
Posted: Sun May 06, 2012 3:28 pm Post subject: |
| Thanks Richard I'll try number 2 next time |
| Back to top |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 2913 Location: East Sussex, UK
Posted: Sun May 06, 2012 4:52 pm Post subject: |
| Oldboy wrote: | 2: Download as a single CSV, or ASC, file as use MakeOV2 to convert the text file.
#2 is quicker, once the MakeOV2.exe is available, as you can simply drag the text file to MakeOV2 for the conversion to be almost instant. |
I wanted to give this a try, as it seems much simpler than POIEdit. I've downloaded and unzipped ov2tools.zip, but when I double-click MakeOV2 a command prompt window flashes on the screen for a fraction of a second, but I can't access it. I've tried using the Start command to access it with the same result.
OS is Windows 7. Any suggestions would be much appreciated! _________________ Anita
TomTom GO 720 with RDS-TMC
App: v9.510
Map: v910.4892 UK & RoI |
| Back to top |
AliOnHols Pocket GPS Verifier
Posted: Sun May 06, 2012 5:45 pm Post subject: |
Hi Anita, Have you tried switching Win7 to compatibility mode? Not being a Windows man myself I'm not sure how to do this but I have seen it mentioned more than a few times. _________________ TomTom GO 730, GO 930, GO 940 & Rider2.
SatMap Active 10.
Android with CamerAlert, OsmAnd+, Waze & TT Europe. |
| Back to top |
Posted: Sun May 06, 2012 5:57 pm Post subject: |
In the Zipfile you downloaded is a Text File with instructions.
The 2 methods for using MakeOV2.
1: Open a command window first and navigate to the Folder where MakeOV2 is. On the Command Line type "MakeOV2 inputfilename" without the quotes. The Input File should be in the same Folder.
2: (To my mind the quicker and easiest method). Use Windows Explorer to navigate to the correct Folder. Left Click the Input File, and Drag to MakeOV2.
MakeOV2 can be placed in any Folder. I use a "POI Folder" where I place all the Files I need to convert.
I don't use Windows 7, but I assume Windows Explorer is the same, and I haven't had to use MakeOV2 for a couple of years now. _________________ Richard
| Back to top |
Posted: Sun May 06, 2012 6:18 pm Post subject: |
| Oldboy wrote: | In the Zipfile you downloaded is a Text File with instructions.  | I have never before heard RTFM put in such a charmingly polite way
But I suppose that it was because you were addressing a lady  |
| Back to top |
Posted: Sun May 06, 2012 6:47 pm Post subject: |
I did RTFM, but this is all the text file has about MAKEOV2:
| Quote: | MAKEOV2 1.1
The use of MAKEOV2.EXE is as follows:
MAKEOV2 inputfilename [outputfilename]
The input file should be a text file (extension ASC is recommended!) that
should simply contain lines of text. Any line starting with a semi-colon
will be ignored. Empty lines will also be ignored. All other lines are
expected to represent points of interest. Such a line should specify a
longitude, a latitude and a name, seperated by commas.
It is recommended that the name is put between double quotes.
A name should not contain double quotes. Longitudes and latitudes may be
specified either as degrees and fractions of degrees, or in degrees,
minutes and seconds. Both colons and single-quote/double-quote notation
may be used for minutes and seconds. So, all the following lines are
all equivalent:
53.5 , 4 , "Truckers Restaurant La Bamba"
53.5000000 , 4.00000000 , "Truckers Restaurant La Bamba"
53'30"00 , 4'00"00 , "Truckers Restaurant La Bamba"
53'30 , 4'0 , "Truckers Restaurant La Bamba"
53:30:0 , 4 , "Truckers Restaurant La Bamba" |
Maybe I should do a fresh download.
I have to go out now, but I'll try the instructions in your post as soon as I get back. _________________ Anita
App: v9.510
| Back to top |
Posted: Sun May 06, 2012 7:06 pm Post subject: |
| I tried it on the ATM POIs and it worked first go. I just dragged the .csv file onto the makeov2.exe icon and hey presto a .ov2 file was created. No need to try and open makeov2.exe |
| Back to top |
Posted: Sun May 06, 2012 7:39 pm Post subject: |
| M8TJT wrote: | | But I suppose that it was because you were addressing a lady | I try to treat everyone with the same courtesy - unless I have good reason to do otherwise.
| Anita wrote: | | I did RTFM, but this is all the text file has about MAKEOV2: | That's all there is.
| EGLITTLE wrote: | | I just dragged the .csv file onto the makeov2.exe icon and hey presto a .ov2 file was created. | Like I said - 'quicker and easier'.
Simplezz _________________ Richard
| Back to top |
Posted: Sun May 06, 2012 9:47 pm Post subject: |
| Oldboy wrote: | | M8TJT wrote: | | But I suppose that it was because you were addressing a lady | I try to treat everyone with the same courtesy - unless I have good reason to do otherwise.  | There was absolutely no implication that you don't. I was congratulating you on your perfect manners. (Unlike myself ) |
| Back to top |
Posted: Sun May 06, 2012 11:06 pm Post subject: |
| Oldboy wrote: | | 2: (To my mind the quicker and easiest method). Use Windows Explorer to navigate to the correct Folder. Left Click the Input File, and Drag to MakeOV2. |
Thanks, Richard, as you said it's very quick and easy , but with just the instructions in the text file I wouldn't have known that was what I had to do. I've added your above instruction to the file so when I come to use MakeOV2 again I've got a reminder if I need it! _________________ Anita
App: v9.510
| Back to top |
Posted: Mon May 07, 2012 7:01 am Post subject: |
| Anita wrote: | | I've added your above instruction to the file so when I come to use MakeOV2 again I've got a reminder if I need it! | It must be 7-8 years since I read the text file, and I'd forgotten that it was an undocumented feature.  _________________ Richard
| Back to top |
Posted: Mon May 07, 2012 10:37 am Post subject: |
That's fine, Richard, I'm just glad you mentioned MakeOV2 here at all.
I didn't download POIs very often because it was such a drag having to decide which 20 subcategories to choose from the large categories like supermarkets and food & drink, and the POIEdit approach is so cumbersome. I hadn't realised there was such a simple way of doing it, and will now make much better use of the POIs.
Maybe a link to this method could be added to the note on the download page? _________________ Anita
App: v9.510
| Back to top |
| Back to top |
