Ezy162 Occasional Visitor
Posted: Mon Jul 16, 2007 2:11 am Post subject: I Cant get the speed camera database to work. |
i have tomtom mobile 5 and i ave europe but split into sections like benelux, france, uk etc. I have europe speed camera databse. I copy all of the Ov2 files with the .BMP and paste it into each folder but when i open tomtom there is no camera's, please help.
matt |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10641 Location: Suffolk, UK
Posted: Mon Jul 16, 2007 6:49 am Post subject: |
You say the cameras are not in the Map Folders.
Have you set up Warn When Near for each, and every, Folder? You will need to do it for every OV2 File you have copied, and in every Map!
Or have you got more than 39 POI categories in each Map, so that they don't show up in the List you Select from? _________________ Richard
Posted: Mon Jul 16, 2007 12:47 pm Post subject: |
hi richard thanks for the reply. I have got all the ov2 in the map folders, as i say there are 7 folders for different like france, spain etc. so i copied and pasted the ov2 into each one of them folders, and it is the europe camera databse i have.
I do not have more than 39 POIs, and alerts are set. They are just not showing on the map , i also have a tomtom one 300 and still does not work. I have followed all the steps correctly and still no joy, any more advice? |
Posted: Mon Jul 16, 2007 1:51 pm Post subject: |
Ezy162 wrote: | I do not have more than 39 POIs, and alerts are set. They are just not showing on the map , | Are you saying that you have setup the Warn When Near, or have you just Enabled them?
If Warn When Near is set up, you won't see the Icons on Browse Map. You will only see them in the Navigation Map. You will also only see them while using a Route if you ticked the Option, in the Warn When Near Menu, to Warn only if POI is on Route.
To see/hear them when using 'free' navigation you need to leave that Option unticked.
You also won't see them unless the Map is showing the area where the cameras are. If you have the France Map open, you would only see them if you use Browse Map and the Cameras have been Enabled. You wouldn't see them in the Navigation Map unless you were in France.
The Europe Database doesn't have any cameras for the UK. You need the UK File(s) for that. _________________ Richard
Posted: Mon Jul 16, 2007 3:21 pm Post subject: |
ok richard, thanks. Everything is fine because when before they worked fine and this is just an update and i have replaced the ov2. So it should show with the settings i have. as for the uk, i have the may 07 database is this the most recent? if not can you post link to most recent thanks |
Posted: Mon Jul 16, 2007 4:32 pm Post subject: |
yay, i got it to work think i had to many options ticked BUT there arent very many cameras showing up in europe!!!! and its the june 07 version, any suggestions also is there an update from may 07 Speed camera databse? link?
cheers |
Posted: Mon Jul 16, 2007 4:38 pm Post subject: |
The large yellow box with a picture of a speed camera on it at the top left of this page is a link straight to the downloads page, click this and you will be taken to the page where you can select the latest database of your choice, out of interest where did you get the database you are currently using? - Mike |
Posted: Mon Jul 16, 2007 6:45 pm Post subject: |
i got mine from this site. is there a POI datbase i can download? |
Posted: Mon Jul 16, 2007 6:52 pm Post subject: |
On the left of this page is a hyperlink under Points Of Interest/ Download POI's - click that to be taken to the normal POI downloads page, don't forget you can only have upto 39 custom POI categories with the version of software you are using - Mike |
Posted: Tue Jul 17, 2007 6:08 pm Post subject: |
those POIs dont work. I extracted them and put it into the folder map and they havent appeared on the POI in tomtom? |
Posted: Tue Jul 17, 2007 6:21 pm Post subject: |
They most certainly do work, but you are using TT Mobile version 5 which is limitted to 39 custom POI categories, check the number of files ending with an extension of .ov2 within the map folder - if there are more than 39 ov2 files that is your problem - Mike |
Posted: Tue Jul 17, 2007 6:32 pm Post subject: |
do custom ones include the cameraS?
also i want belgium aswell do i tick the box as well as the UK and plzce the download 'POIs' into the beligium and uk folder? |
