Alang Occasional Visitor
Posted: Sat May 06, 2006 9:01 pm Post subject: How do I rollback to 2.70? |
The title asks the question!
Thanks in advance for your help.
Alang |
timber Frequent Visitor
Joined: Jan 18, 2006 Posts: 422 Location: Wild and Windy SW Scotland UK
Posted: Sat May 06, 2006 9:17 pm Post subject: Re: How do I rollback to 2.70? |
Alang wrote: | Hi
Alang |
unzip file connect your I3 using usb cable back up any favorites (They will be lost otherwise) then install the following.
http://makeashorterlink.com/?C1AF2211D
Will host for 48 hours |
Posted: Sun May 07, 2006 1:10 pm Post subject: |
Hi timber
Thanks for help, its all sorted now. :D
I had downloaded 2.70 into the wrong folder, thats why I could not get it to work.
Alang |
Coaster2 Lifetime Member
Posted: Tue May 16, 2006 8:57 pm Post subject: |
Sorry to be a pain but I'm new to this. I am on V3 and it is rubbish. I've downloaded v2.7 which was fine. How do I go about getting 2.7 back into the i3 please? |
Posted: Tue May 16, 2006 9:21 pm Post subject: |
Coaster2 wrote: | Sorry to be a pain but I'm new to this. I am on V3 and it is rubbish. I've downloaded v2.7 which was fine. How do I go about getting 2.7 back into the i3 please? |
Double click on the 2.70 zip file then select a folder to unzip to suggest c:\temp.
Have you installed the I3 usb driver if not obtain from here and install
http://www.garmin.com/support/download_details.jsp?id=591
Now connect the I3 to your PC using the usb cable the i3 will power on its self.
Go to the folder you unzipped 2.70 to and double click on the loader icon select usb option and then select next.
Accept the warning that you are going to put a earlier release of software on and proceed on let the erase and load take place untill the message comes up that it has finished.
Go through the settings and ensure they are to your satisfaction (they have all been set to default)
And that should be you back on 2.70 |
Posted: Tue May 16, 2006 9:28 pm Post subject: |
Many thanks Timber; job done. |
Posted: Tue May 16, 2006 9:57 pm Post subject: |
One thing I found was that it erased all my favourites. Is there any way that these can be backed up? |
Posted: Tue May 16, 2006 11:04 pm Post subject: |
Coaster2 wrote: | One thing I found was that it erased all my favourites. Is there any way that these can be backed up? |
As for backing up your favorites download from here :
http://www.easygps.com/download.asp
When you have downloaded and installed select preferences and then add gps from dropdown menu select garmin and finally I3.
Receive will read from the I3 and of course send does what it says.
When you read you then can save to your PC so that next time you can load this file and send direct to the I3 |
Posted: Wed May 17, 2006 12:11 am Post subject: |
Many thanks Timber, works a treat. |
