Pocket GPS World :: View topic - Activesync - Critical Communications Error - FIX
Steve101
PostPosted: Mon Oct 17, 2005 7:47 pm    Post subject: Activesync - Critical Communications Error - FIX Reply with quote
Critical communications services have failed to start. Try resetting the mobile device, and then connect again.
I think I may have finally solved this problem. Well it works for me anyway. Here goes....
There is no need to try and re-install Activesync, as there is probably nothing wrong with it. That's why when you re-install it you get the same error message.
The way I got around this problem is this: Have a look in your Firewall program where you have a list of Blocked or Allowed Internet programs.
In here look for these programs: Windows Explorer, ActiveSync Application and ActiveSync Connection Manager.
Make sure that these 3 programs are allowed either Full Access, or Outbound Access Only.
I have mine on Full Access and it works ok.
I tried denying access to Windows Explorer but this brought the error back up again.
I think this is the only reason the error occurs and it is definitely nothing to do with Activesync.
Hope this helps!!!
22.043 (17 Apr 24)
