Pocket GPS World :: View topic - Palm - Installing Safety Cameras to TomTom on Palm OS
Askj
PostPosted: Sat Mar 26, 2005 7:44 pm    Post subject: Palm - Installing Safety Cameras to TomTom on Palm OS Reply with quote
Hi, I was wondering if anyone can help me, I would like to add the safety cameras etc to my PDA but do not know how to do it. I am a very basic user and very new to it all, the GB maps I have are on a CD and not sure how I add files to it to download via hot sync - Can anyone help me?
PostPosted: Sat Mar 26, 2005 8:16 pm    Post subject: Reply with quote
The easiest way to install these on a Palm OS T3/T5 is to use an SD Card Reader.
1. Take the card out of your T5 and place in your SD card reader
2. Double click the driveletter that shows against your newly inserted SD Card
3. Now download the Safety Camera ZIP file and extract the contents to c:\temp
4. Copy the relevant OV2 and BMP files from the main TEMP directory to the COUNTRY_MAP directory on your SD Card (e.g. Great Britain). This will be something like PocketGPS_UK_GATSO.ov2 & bmp. Same goes for the MOBILE and REDLIGHT and SPECS files.
Once copied to your SD card, you can wait a couple of minuted, eject the card and place it back in your Palm.
Soft reset the Palm, and when you now run TomTom Navigator, and go into the POI-Manager you should now be able to see these files and you should be able to enable them for map view and also select the WARN option to warn against each of the POI's.
Robster1975
PostPosted: Sat Apr 02, 2005 1:38 am    Post subject: Reply with quote
Hello Askj
i wanted to know how well your Tungsten T5 is working with Tom Tom navigator as i had read on expansys that it is not compatible
i would be thankful for u r reply
Robster
Robster1975
PostPosted: Sat Apr 02, 2005 1:39 am    Post subject: Reply with quote
Robster1975 wrote:
Hello Askj
i am looking out for a good GPS hardware with my T5
Robster
PostPosted: Sat Apr 02, 2005 12:41 pm    Post subject: Reply with quote
Officially, TomTom only support the Palm T5. Whats different in the T5 to the T3 ? The only thing I'm aware of is the bottom connector is physically different. Currently you can only purchase the Palm OS version with the car cradle and BT GPS.
Mr-B
PostPosted: Fri Apr 08, 2005 12:59 pm    Post subject: Reply with quote
This is incorrect surely?
TT have never supported the T5, it's just the Tungsten C and T3.
http://www.tomtom.com/products/compatibility.php?ID=5&Language=1
harbro
PostPosted: Sun May 01, 2005 5:35 pm    Post subject: Installing safety camera database Reply with quote
Purchaced TomTom for Palm T3 a couple of weeks ago (new, from a well known high street store) and have had problems installing the safety camera database. Until that is I found that the TomTom software was v4.0. Now I have downloaded the free upgraded to v4.4 via the TomTom website the problem has been solved. So check your software version - it's on the GPS status page.
JimP25
PostPosted: Tue Oct 11, 2005 8:37 pm    Post subject: Re: Installing safety camera database Reply with quote
Thank you for the above. This has solved my problem too. Again, many thanks to you all.
22.043 (17 Apr 24)
