bazzza Frequent Visitor
Joined: Nov 05, 2006 Posts: 260 Location: East Yorkshire
Posted: Mon Jan 09, 2017 8:00 pm Post subject: Lost camera voices when not navigating |
My VIA 135 works perfectly when it is navigating but its camera warning voices are not there when it isn't, even though the cameras show on the screen.
Also, it quite often doesn't switch on automatically when the ignition is turned of and then back on. I guess it's in the Setup but I can't find where. _________________ Bazzza
TTGO520 Version 9.430
Western & Central Europe Maps
Iphone 6
TT Via 135M
GO520 WiFi |
M8TJT The Other Tired Old Man
Posted: Mon Jan 09, 2017 8:31 pm Post subject: |
Can you clarify your first sentence bazza. Do you mean the the camera audible warnings are there when you are following a route, but not there when just driving about?
Are you using Kremmen's CSV to GPX converter? If not, the Garmin has a habit of not warning you when approaching a camera when you are below the speed limit. Kremmen's prog overcomes this 'shortcoming'. |
marksfish Pocket GPS Verifier
Joined: Jun 25, 2005 Posts: 802 Location: Sandy, Bedfordshire
Posted: Mon Jan 09, 2017 10:08 pm Post subject: |
The via 135 is a TomTom unit M8TJT
When you set up proximity alerts, there is a check box for "only sound when on route", or similar. If that box is checked, then it will only sound when a route is planned. You will have to check each alert you have set up as it is not a universal setting.
Mark _________________ Garmin Drivesmart 51 LMT-D Europe |
Posted: Tue Jan 10, 2017 12:17 am Post subject: |
Thanks Mark. I think that was the problem. I will check it tomorrow. _________________ Bazzza
Iphone 6
TT Via 135M
GO520 WiFi |
Posted: Tue Jan 10, 2017 7:02 pm Post subject: |
Thanks Mark, it's ok now. In the process of doing it, when it asks if you want to delete the camera I inadvertently clicked on "Yes" and lost a camera (60mph Gatso) which I can't get back. Can you help me get it back? _________________ Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
Posted: Tue Jan 10, 2017 7:20 pm Post subject: |
marksfish wrote: | The via 135 is a TomTom unit M8TJT | Doh. |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10641 Location: Suffolk, UK
Posted: Tue Jan 10, 2017 9:00 pm Post subject: |
bazzza wrote: | ... and lost a camera (60mph Mobile) which I can't get back. | All you have done is removed the Warn when Near setting for the camera. You don't delete the actual files associated with the Mobile 60 cameras.
Just repeat the Warn when Near procedure for that camera again. _________________ Richard
Posted: Tue Jan 10, 2017 9:53 pm Post subject: Lost camera |
Oldboy wrote: | bazzza wrote: | ... and lost a camera (60mph Mobile) which I can't get back. | All you have done is removed the Warn when Near setting for the camera. You don't delete the actual files associated with the Mobile 60 cameras.
Just repeat the Warn when Near procedure for that camera again. |
I can't do that as the camera is not now in the list of POI Categories. How do I get it in there?
Sorry to be a pain. ps. It was a Gatso 60 camera, not a mobile. _________________ Bazzza
Iphone 6
TT Via 135M
GO520 WiFi |
Posted: Wed Jan 11, 2017 8:21 am Post subject: |
In that case there are two possible scenarios.
1. You actually deleted the Gatso 60 POI file, in which case you need to re-instate it from the downloaded zip file. If you've already deleted that also, you can download the cameras again.
2. You have a large number of OV2 files in your Map folder. There is a limit to how many items a TT can display in any menu.
If the Gatso 60 OV2 file is definitely on the Device, you would need to move a few of the other OV2 files to another location, until the Gatso 60 did show in the Warn when Near list. Once set up the removed OV2 files can then be placed in the Map folder again. _________________ Richard
Posted: Wed Jan 11, 2017 7:40 pm Post subject: |
Thanks Richard. Back to normal now. I'm grateful. A new download of camera files did the trick. _________________ Bazzza
Iphone 6
TT Via 135M
GO520 WiFi |
