Graham_G Occasional Visitor
Posted: Wed Jul 27, 2016 10:47 pm Post subject: Strange routing on nuvi 250 (CN 2017.10) |
I recently updated the maps on my Nuvi 250 - only with the UK and Ireland segment of CN Europe 2017.10 since I'm not going anywhere foreign this year, and then took it on holiday to West Wales, mainly the area between St Davids and Aberystwyth, which I am almost completely unfamiliar with and so needed to be able to rely on my Satnav.
During the week there the unit tried to make me do some crazy things. On one of the roads leading NW-SE - possibly the A482, I can't remember, there is a row of oldish houses set back from the main road on their own little parallel road joined to the main road at both ends. As I approached this formation at 60mph, the unit tried to get me to go off the 'A' road, down the little street of houses and back onto the 'A' road instead of just staying on the 'A' road. By no stretch of the imagination was the loop road shorter, so it wasn't as though the unit was just trying to take me by the shortest, most direct route.
This was just one of many instances in which the unit tried to take me down unsuitable narrow bypasses and backroutes instead of just handing me from one 'A' road to another a few hundred yards further on. The unit's behaviour was pretty much as though I had a mode called 'Avoid main roads whenever possible' turned on.
The actual relevant settings are 'Fastest Time' (rather than ' Shortest Route') and in the avoidances only 'Avoid Toll Roads' was turned on. 'Avoid main roads' is OFF.
Anyone else been having problems like this?
I'm pretty sure the unit never used to do this earlier in its life, when it used to route sensibly. The unit has had the latest firmware available (for the Nuvi 250) for some years now. One thing I might consider is going back to older firmware if I can find it. |
M8TJT The Other Tired Old Man
Posted: Wed Jul 27, 2016 11:35 pm Post subject: Re: Strange routing on nuvi 250 (CN 2017.10) |
Graham_G wrote: | Anyone else been having problems like this? | Yes. Most peeps with Garmins have this sort of thing happen to them from time to time. Bloody poor routing algorithm. Sometimes makes absolutely no sense what so ever. |
Kremmen Pocket GPS Verifier
Posted: Thu Jul 28, 2016 4:55 am Post subject: |
Agree, this is another post of a similar nature that is becoming quite common.
Maybe contact Garmin as they 'must' be getting complaints about this poor behaviour.
If sussamb sees this he should know the best way to contact them for this. _________________ Satnav:
Car Average MPG :
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4456 Location: West Sussex
Posted: Thu Jul 28, 2016 6:05 am Post subject: |
Well the first thing to try is a master reset. Ideally that should be done after any software or map update, as it generally cures any weird behaviour like that.
You can then run your nuvi in simulation mode to see if it still does it, but this needs you to remember where it happened, and it sounds like you can't?
If it still does it after a master reset then it's worth contacting Garmin.
Should you wish to revert to an older firmware this can be done fairly easily but unless you can recall where the events happened you can't really compare the two. _________________ Where there's a will ... there's a way.
Posted: Thu Jul 28, 2016 6:54 am Post subject: |
Kremmen wrote: | Agree, this is another post of a similar nature that is becoming quite common. | There has been posts like this about Garmin's routeing for as long as I've been into sat navs K. They seem to be mostly about routeing in the West Country or other less populous areas. I have never had a problem with iGO routeing and would use that exclusively if I could get a version with traffic. |
Posted: Thu Jul 28, 2016 7:15 am Post subject: |
Absolutely. It's the digital traffic that keeps me with Garmin but as you know I don't use my Garmin for routeing.
iGo with it's directional cameras sounds better. _________________ Satnav:
Car Average MPG :
Posted: Thu Jul 28, 2016 7:39 am Post subject: |
I rarely have issues with Garmin routeing and use Garmins extensively in the UK, France, Spain and Portugal. One thing with modern Garmins is that they have two features that are meant to help improve routeing. One is myTrends that suggests routes that it knows you use frequently. The other is TrafficTrends. This is aimed at predicting traffic flow from historical data, that is updated on your nuvi when you update maps, so will route you taking that into account.
The latter can certainly cause what appears to be weird routeing, which often varies on the same route at different times of the day. Since I find the digital traffic excellent I have TrafficTrends turned off. _________________ Where there's a will ... there's a way. |
Posted: Thu Jul 28, 2016 7:48 am Post subject: |
So I reckon, based on your better knowledge, that every map update should trigger a unit master reset.
Why am I so clever _________________ Satnav:
Car Average MPG :
Posted: Thu Jul 28, 2016 7:58 am Post subject: |
There are only two or three roads it could really have been, given where I went during the week. I may try 'flying' along over each of them on Google Earth to try to spot the little loop road with the houses on, and then drop down there on StreetView to see if it's the place. I would recognise it if I saw it again.
If I can ID it that way I'll try to simulate a run along past that point. |
BigJohnD Frequent Visitor
Joined: Aug 26, 2007 Posts: 394 Location: Glannau Mersi, Lloegr
Posted: Thu Jul 28, 2016 9:54 am Post subject: |
Garmin does produce some odd routes, often along country lanes. It happened to me earlier in the week in Cheshire.
M8TJT wrote: | I have never had a problem with iGO routeing and would use that exclusively if I could get a version with traffic. |
Likewise.
IGO has a routing option called "Easy" which I love. I think it was aimed at caravans and motorhomes. The route was not the shortest nor always the quickest, but it would use major roads all the time, even if it was significantly longer.
I have suggested a similar option to Garmin several times.
I have also suggested they use road numbers (e.g. A56) rather than names (e.g. Chester Road) at junctions. |
Posted: Thu Jul 28, 2016 10:10 am Post subject: |
Certainly more road numbers are now being used by Garmin than ever before, and it's a bit like junction view, more are added each map update.
As for an easy or 'use main routes only' option if enough folks ask for it Garmin tend to introduce it, I guess not enough of us ask for this particular option _________________ Where there's a will ... there's a way. |
Posted: Thu Jul 28, 2016 3:52 pm Post subject: |
Well, surely enough peeps have asked for better routing. |
