Pocket GPS World :: View topic - Garmin NUVI 50 Cameras and Voice Alerts
Goto page Previous  1, 2
meditek
PostPosted: Thu Jan 01, 2015 3:28 pm    Post subject: Reply with quote
What distance from the camera site triggers these warnings. I ask because North Yorkshire is infested with converted vans stuffed with gear that can get you up to a mile away according to the guy giving our badboy lecture.
PostPosted: Thu Jan 01, 2015 6:29 pm    Post subject: Reply with quote
This is my issue with Garmin. By default it's 36 seconds which I think is too early. As a result I wrote the CSV to GPX converter, available in the sticky section above. That allows you to set your own approach and secondary overspeed warnings. I use 14 seconds for approach and 6 seconds if I'm still over the limit at that point.
It also removes some of the annoying double warnings where there are cameras on both sides of a motorway gantry for example.
Satnav:
Car Average MPG :
meditek
PostPosted: Thu Jan 01, 2015 6:43 pm    Post subject: Reply with quote
I should prefer it by distance, unless of course the gizmo works out the time related to speed internally. Mine does not have the speed related ability so I should be happy to receive the warning at least a mile before. When you can see them it's too late!
PostPosted: Fri Jan 02, 2015 5:49 am    Post subject: Reply with quote
If you're looking at a mile then you are going to get dozens of simultaneous warnings in urban areas as it works on a forward radius.
Even at 36 seconds you stand a chance of forgetting. I based my preference on my old Talex that I thought had it spot on.
Satnav:
Car Average MPG :
PostPosted: Fri Jan 02, 2015 9:34 am    Post subject: Reply with quote
It depends on how straight the road is. Have a look at the various types etc. here The maximum displayable range of the LTI 20-20 is 999 metres (I've seen one), which is 3309 ft, nearly 1010 yards or about 0.62 miles. Its principal specifications are:
Marksman Specifications LTI 20-20
Dimensions: 3.5 in x 5 in x 8 in
Weight: 4.5 lbs
Speed Measurement Distance: 30 ft to 3500 ft. 300mts With Video Camera
Speed Maximum: +200 mph to -200 mph (accurate zero reading) Accuracy: +/- 1 mph
Acquisition Time: 0.3 seconds
Range Measurement Distance: 30 ft to 3500 ft Accuracy: +/- 6 inches
Targeting
Pin-point beam (3 milliradian divergence, 3 ft wide at 1000 ft)
Others are similarly specified, so it's very unlikely that they will trap you much beyond half a mile and then only if tripod mounted. And at 60MPH, half mile is 30 seconds. Note the acquisition time of one third of a second, which is why laser detectors are a waste of money.
And remember that police can set up a speed trap wherever they like, so no database will be completely accurate anyway.
[patronising mode]
So the only way of being completely safe is not to speed.
[/patronising mode]
meditek
PostPosted: Fri Jan 02, 2015 10:35 am    Post subject: Reply with quote
The vans here are unmarked and look like 'white vans'. on close inspection they have small portholes dotted around. They park them over the brow of a hill or similar and then knock off back to their desks for a few hours. The things are fully automated and check for seat belts, tax discs- no longer, and speed. They have started doing people for 32, 43 and so on mostly parking in places where no serious accidents have been recorded. The spate of 'low speed' convictions ensures their expensive lectures are well attended.
Page 2 of 2
