Newsletter
Pocket GPS World :: View topic - TomTom start 25 Access
spod22
PostPosted: Sun Mar 25, 2012 5:05 pm    Post subject: TomTom start 25 Access Reply with quote
Hi First post here well for a long time and on this divice
Im just wondering if thire is a software program that allows me to gain access to the operating system on this divice the divice dose not show up in windows as a drive
I also seem to be having dificulty placing files on to the micro card, my TomTom gives me no option to place files on the card, the card is visable in my TomTom any thoughts ideas on this
Thanks Rich Very Happy
PostPosted: Sun Mar 25, 2012 5:36 pm    Post subject: Reply with quote
You can only use the MyTomTom interface to communicate with the device from the PC otherwise it sits hidden away with none of the older options for adding files to the device available to you. This is the main reason I would never recommend one of these newer devices that are dependent upon the crap PC interface softeare, no way to back up the unit or re-install said back up, you are at TomTom beck and call - Mike
PostPosted: Mon Mar 26, 2012 3:56 pm    Post subject: Reply with quote
As Mike says, there is no way to access the system other than by MyTomTom, it's locked down pretty well.
However, I wouldn't go so far as Mike does about not recommending any of these models. Basically, if you want a TomTom, you have to learn to live with the new system.
Most of what most people would want to add can now be added simply enough in MyTT.. The lack of backup is a pain, but so far I've not seen many situations that the new emergency recovery schemes built in to MyTomTom can't get you out of.
So... the second part of your question... What did you want to put on the SD card and why?
The way it is organised now is that the SD card really is just treated as an extension to the internal memory, so there's nothing that NEEDS to go in any particular place. Just fill up the internal memory until there's no more room and then it will use the SD card instead.
"Settling in nicely" ;-)
spod22
PostPosted: Mon Mar 26, 2012 10:16 pm    Post subject: thanks Reply with quote
Ok Thanks for the replys
I just realy wanted to ad third party POIs like Bridges, would have been handy to add the full truck navcore as im not sure the europe truck map will work with out the navcore part so looks like ive bought the wrong unit saying that I have managed for years with out dedicated truck software
Thanks again Rich Very Happy
PostPosted: Tue Mar 27, 2012 2:57 pm    Post subject: Reply with quote
POIs etc. will go on the unit just fine (either onto the internal memory or an SD card if there's not enough space on internal).
I'm afraid your chances of getting "truck" software onto it are pretty much zero though.
11.062 (12 Jun 13)
