| Author |
Altea Occasional Visitor
Posted: Sat Mar 03, 2012 12:06 am Post subject: Full postcodes using Go 500? |
My Go 500 will not accept full postcodes, it will only take the first part of the code. This is useless as postcode areas can be huge so there's no chance of getting to destination if the street/road is unknown. So, is there a way to get this to work?
Cheers. |
| Back to top |
AliOnHols Pocket GPS Verifier
Posted: Sat Mar 03, 2012 7:52 am Post subject: |
What version of the postcode zip file do you have installed and how current are your maps?
Has it ever worked correctly for you?
Have you recently done anything to your TT which may have changed some settings?
EDIT - Just to confirm, do not put a space between the 2 parts of the post code, enter it as one long 6/7 digit code. _________________ TomTom GO 730, GO 930, GO 940 & Rider2.
SatMap Active 10.
Android with CamerAlert, OsmAnd+, Waze & TT Europe. |
| Back to top |
Posted: Sat Mar 03, 2012 12:11 pm Post subject: |
Thank you for your reply.
I'm sure that when I first bought the unit it did accept the full postcode - though this is a long time ago and I haven't used that feature until a couple of days ago, when I only had a postcode, not an address. I'm up to date with the maps as I subscribe to the map updater.
I've looked at what's on the memory card but can't find anything obvious that looks like a postcode file. Perhaps I'm looking in the wrong place, and it's hidden in another file somewhere.
Finally, I've not done anything to the unit except have Pocket GPS World camera database and custom voice loaded. |
| Back to top |
Posted: Sat Mar 03, 2012 12:28 pm Post subject: |
I've looked again and found an item within the map folder that is called 'postal_GBR.ttd'. However, there isn't a version number. It only says that it was modified today( because I have just downloaded the latest map update.)
By the way, I installed the PGS World camera database and custom voice a long time ago.
John |
| Back to top |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2309 Location: Toronto CANADA
Posted: Sat Mar 03, 2012 12:56 pm Post subject: |
Do this .......
Download this compressed file:
http://www.tomtom.com/updates/zipcodes/Map_885/zip.zip
and use WinRar to extract the contents to a FOLDER called zip (all lower case) in the root of the unit.
Thus, you should find up with a folder called zip AND the contents of the zip file (confusing with the naming, eh?) on the unit. _________________ David
--TomTom 720 NA map 895 WCE map 840 NZ map 835
--540 WTE NA map 885 Europe_West 885 |
| Back to top |
Andy_P Pocket GPS Moderator
Joined: Jun 04, 2005 Posts: 19390 Location: West and Southwest London
Posted: Sat Mar 03, 2012 1:00 pm Post subject: |
| Altea wrote: | | I've looked again and found an item within the map folder that is called 'postal_GBR.ttd'. |
That is a NEW system to deliver the postcodes to the latest models. All the older models (the ones that use "Home" on the PC for updates) use the "zip" folder method.
dhn is putting you on the right lines.....
But personally, rather than using WinRar, I would do the extraction with Window's own built-in extraction just by right clicking on the downloaded file and selecting "Extract all".
That will save the folder you need onto the PC and you can then COPY it to the TomTom.
Just seems easier to me that way.
I only use WinRar when I have to... for unpacking the ".cab" files used by TomTom sometimes.
For ordinary .zip files Windows own routine works fine.
(For Macs.. they seem to have troubles with their own extraction methods and people do have to use third-pary solutions like Stuffit etc.) _________________ "Settling in nicely" ;-) |
| Back to top |
Posted: Sat Mar 03, 2012 1:53 pm Post subject: |
Thank you dhn and AndyP. I will give that a go.
John |
| Back to top |
Posted: Sat Mar 03, 2012 6:45 pm Post subject: |
| Done all that but still no joy. I now have a couple of files in my map folder that are called Great_Britain.postal and another Great_BritainPostal.ver. Still won't accept full postcodes though. Maybe I'm doing something wrong. |
| Back to top |
Posted: Sat Mar 03, 2012 7:04 pm Post subject: |
Those files NEED to go into a FOLDER called zip in the root of the unit, NOT in the map folder as individual files. _________________ David
| Back to top |
Posted: Sat Mar 03, 2012 7:20 pm Post subject: |
| Can't find a folder called 'zip'. Where do I look for it?I've looked at everything that shows on the Tom Tom when I connect to my computer. Sorry, I'm not up on these things. |
| Back to top |
Posted: Sat Mar 03, 2012 7:41 pm Post subject: |
When you "unzipped the download" it should have ended up in a normal folder called zip and you copy the whole thing across, but if not, it doesn't matter... you can just make one.
You can do that by right clicking in the window in Windows Explorer and selecting "New" then "Folder" or by selecting "New" then "Folder" from the File menu at the top. Then put all four files back inside it.
Here's what it should end up looking like in Windows Explorer.
The TomTom will have lots of folders, one of which has to be called "zip" and that folder has the four files inside.
(The other folders will include your UK or Europe map folder and will be somewhat different on a Go500 to what's in my picture)
| Back to top |
Posted: Sat Mar 03, 2012 7:45 pm Post subject: |
If you do not have a folder named "zip" you can create one yourself. Once you have plugged your TT in to the computer, opened Windows Explorer and clicked the TomTom icon so you can see the files, right click on the TomTom icon and a sub menu should open and one of the choices should be "create new folder" select this, call the new folder "zip" without the quotation marks. So now the new folder zip shall be added to the root of the TT and you should be able to see this new folder, along with all the other folders when you select the TT icon. It is into this folder that you place the contents of the 885 zip download once you have unzipped/expanded them.
Edit - Doh! wot genesis says above  _________________ TomTom GO 730, GO 930, GO 940 & Rider2.
SatMap Active 10.
| Back to top |
Posted: Sat Mar 03, 2012 7:59 pm Post subject: |
Success! That's done the trick! Thanks everyone for your help.
John |
| Back to top |
Posted: Sat Mar 03, 2012 8:06 pm Post subject: |
| Altea wrote: | Success! That's done the trick! Thanks everyone for your help.
John |
Excellent, now make a BAckUp using Windows Explorer and keep it somewhere safe on your computer. _________________ TomTom GO 730, GO 930, GO 940 & Rider2.
SatMap Active 10.
| Back to top |
Posted: Sat Mar 03, 2012 8:15 pm Post subject: |
| Will do. Thank you. |
| Back to top |
| Back to top |
