Newsletter
Pocket GPS World :: View topic - Zenec NC3810 unit
Zenec NC3810 unit
marcus_nichm
PostPosted: Fri Apr 22, 2011 1:52 pm    Post subject: Zenec NC3810 unit Reply with quote
i have the above unit, can be seen in the link below... http://homeavdirect.co.uk/zenec-ze-nc3810-double-din-ford-dvd-monitor-navigation
i have set the option to 'warn of speed cameras' ec but none are shown up! i am wanting to pay and download the database from here but i need to know that it will work!
the unit uses the IGO8 sat nav, and its updated via the naviextras website. hav to plug a USB into the unit, then to the laptop where updates are stored, then this USB is plugged into the unit again and the updates are done...
hope this makes sense, but can anybody advise me on weather it will work?
cheers
Marcus
PostPosted: Fri Apr 22, 2011 2:44 pm    Post subject: Reply with quote
Well, iGO8 definitely works with our speed cam database. The only issue is how will you get the db onto the unit? If you can access some sort of file manager on it, it is a case of copy/paste into the right place. Instructions found Here .
If you have speedcams already on the machine, they should be displayed. Settings-Warnings Check Speed camera warnings, then goto the Speed Camera settings and check Visual and Audible warnings. This should display all the cams, but they will not alert on a simulated route, only when driving.
marcus_nichm
PostPosted: Fri Apr 22, 2011 3:15 pm    Post subject: Reply with quote
ill get my subscription sorted then and give it a go...
cheers for the speedy response Cool
marcus_nichm
PostPosted: Thu Sep 29, 2011 10:30 am    Post subject: Reply with quote
hello,
im following on from the thread i started a while ago. ive downloaded a few versions of the databases and uploaded them to my Zenec.
only problem now is... i can get the cameras to show up on the map, but there are absolutely no audible warnings, also each time i plan a new journey, i have to go through the menu and select to display cameras.
any ideas on how to rectify this?
cheers in advance
Marcus
PostPosted: Thu Sep 29, 2011 6:42 pm    Post subject: Reply with quote
Are you displaying them as POIs or from the 'Warnings' menu? If from the warnings menu, the settings should 'stick', but bear in mind that with the standard iGO skin, you have to have a GPS lock before the speedcam options are displayed.
Why have you downloaded 'a few'? You only need one for the UK to start with. Get one working before adding more. Confused
marcus_nichm
PostPosted: Fri Sep 30, 2011 11:01 am    Post subject: Reply with quote
ok silly question, but what is a GPS lock and how do i know if i have one?
im assuming that this happens when the sat nav is in use? i.e. when its directing me?
PostPosted: Fri Sep 30, 2011 12:09 pm    Post subject: Reply with quote
Yes, that is correct. When you first switch on, the unit searches for the sats. Once it has found them, it locks on and then the speedcam menu option is available.
11.053 (15 May 13)
