| Author |
FrequentFlyer Lifetime Member
Posted: Sat Jan 01, 2011 6:02 pm Post subject: Rechargeable Batteries |
| If I were to use the above type of batteries in my A10, can I charge them in situ from the mains, or is the A10 likely to blow up ? |
| Back to top |
Bosun Frequent Visitor
Joined: May 02, 2005 Posts: 470 Location: Wakefield,West Riding of Yorkshire
Posted: Sat Jan 01, 2011 8:31 pm Post subject: |
As far as I know you you can only recharge the Li-Pol battery via the mains.
Wether it would actually blow up if you tried to charge rechargeables I don't know.
Ian |
| Back to top |
Joined: Jan 14, 2005 Posts: 19636 Location: Blackpool , Lancs
Posted: Sat Jan 01, 2011 9:38 pm Post subject: |
I doubt the built in charger circuit will do anything if it doesn't "see" the SatMap rechargeable pack connected as this uses a three pin plug, the normal battery caddy only provides a two pin connection.
The third connection offered with the Li-Pol pack is for temperature feedback to prevent the device catching fire while recharging by regulating the charge current, without this signal I wouldn't expect the built in charger to do anything at all - Mike |
| Back to top |
Gibbo10 Frequent Visitor
Joined: Sep 21, 2008 Posts: 262 Location: Swindon, Wilts
Posted: Sun Jan 02, 2011 1:37 am Post subject: |
I only use AA recharable batteries and can confirm that they do not get charged up, neither does it cause any issues when the USB lead is connected. Don't forget that you need to have batteries in to connect to Satsync. _________________ Satmap A10. Platform 09.02.21, Software version 1.50 Satsync 1.50
GSAK / Quo Mapping
Geocacher ID The K9 Crew
My Blog Geocache Trails |
| Back to top |
Posted: Wed Jan 12, 2011 4:04 pm Post subject: 2900m AH replacements |
| I've now purchased 2900m AH rechargeable batteries....does this mean that the battery performance of my A10 will be much improved compared to the standard Satmap Lipol 2700m AH that I use, or doesn't it work quite like that ? |
| Back to top |
Posted: Wed Jan 12, 2011 6:11 pm Post subject: Re: 2900m AH replacements |
| FrequentFlyer wrote: | | I've now purchased 2900m AH rechargeable batteries....does this mean that the battery performance of my A10 will be much improved compared to the standard Satmap Lipol 2700m AH that I use, or doesn't it work quite like that ? |
No I don't think it works like that, I beleive that your Lipol battery will still give you a longer life but obviously more tricky to change in the field. _________________ Satmap A10. Platform 09.02.21, Software version 1.50 Satsync 1.50
GSAK / Quo Mapping
| Back to top |
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 777 Location: South Lincs, UK.
Posted: Wed Jan 12, 2011 7:15 pm Post subject: |
Is the voltage of the aa batteries the same as the voltage of the lipol battery? If the voltage is the same then I would expect you to get more life from the batteries with a higher mAh rating. In this case about 7% more life. _________________ Paul |
| Back to top |
M8TJT The Other Tired Old Man
Joined: Apr 04, 2006 Posts: 4841 Location: East Sussex, UK
Posted: Wed Jan 12, 2011 8:17 pm Post subject: |
| pcaouolte wrote: | | If the voltage is the same then I would expect you to get more life from the batteries with a higher mAh rating. In this case about 7% more life. | Not exactly 'much improved' though  |
| Back to top |
Posted: Wed Jan 12, 2011 8:21 pm Post subject: |
| M8TJT wrote: | Not exactly 'much improved' though  |
Agreed. _________________ Paul |
| Back to top |
AliOnHols Pocket GPS Verifier
Posted: Wed Apr 18, 2012 6:47 am Post subject: |
Apologies for resurrecting an old topic but it's the closest one I could find that relates to my question.
Q) Is it possible to safely use an external power source while using AA batteries (standard or rechargeable)?.
My reasons -
a) I would like to conserve the charge in the batteries whilst on a car drive by plugging in a cigarette adapter,
b) Towards the end of a walk and with the AA batteries dying down, I'd prefer to plug in a PowerMonkey rather than faff around powering down, fitting a fresh set of AA's and waiting for a GPS lock.
I know I could find out by doing it but it would be nice to know that something isn't going to go Bang! if I do.
Many thanks,
Ali.
Edit, just to confirm, I'm not trying to recharge the batteries but to supplement them. _________________ TomTom GO 730, GO 930, GO 940 & Rider2.
SatMap Active 10.
Android with CamerAlert, OsmAnd+, Waze & TT Europe. |
| Back to top |
Posted: Wed Apr 18, 2012 8:08 am Post subject: |
EDIT to above,
Just in case the answer to the above question is "Yes", it is my intention to use a TomTom Ciggie adapter on my SatMap. The output of this is 5v ~ 1.2A, please can anybody confirm the output of the official SatMap ciggie adapter?
Many thanks once again. Ali. _________________ TomTom GO 730, GO 930, GO 940 & Rider2.
SatMap Active 10.
| Back to top |
rothers Regular Visitor
Joined: Mar 28, 2007 Posts: 129 Location: South Manchester
Posted: Wed Apr 18, 2012 1:39 pm Post subject: |
| 5V @ 600 mA same as the mains charger. |
| Back to top |
Posted: Wed Apr 18, 2012 3:48 pm Post subject: And, for what it's worth.. |
| ...the best rechargeables that I use are Intec2900mHr. Excellent for a full days walking in the hot or cold. |
| Back to top |
sussamb Frequent Visitor
Posted: Wed Apr 18, 2012 4:09 pm Post subject: |
Also Sanyo Eneloops are excellent  |
| Back to top |
Posted: Wed Apr 18, 2012 7:26 pm Post subject: |
Many thanks for your replies.
5v ~ 600mA is half the TTś rating so I shalln't be using the TT adapter.
I have a set of generic 2900mHr and a set of Eneloops, the 2900's lasted about 4hrs and the Eneloops about 5.5hrs. I thought both sets were fully charged before inserting but maybe I was wrong, I shall ensure a fresh, full charge next time and monitor the life span.
If poss I would still be interested if anybody has successfully used an external power source whilst using AA batteries. _________________ TomTom GO 730, GO 930, GO 940 & Rider2.
SatMap Active 10.
| Back to top |
| Back to top |
