Newsletter
Luxury 4 bedroom villa for rent in the Disney Orlando Florida area.
Pocket GPS World :: View topic - RouteBuddy - New iPhone Ordnance Survey Maps Now Out
PostPosted: Sat Aug 15, 2009 4:31 pm    Post subject: RouteBuddy - New iPhone Ordnance Survey Maps Now Out Reply with quote
pocketgpsworld.comRouteBuddy and Ordnance Survey have released 1:50k maps compatible with RouteBuddy's iPhone Atlas Application.
The maps, priced from £9.99 each cover the Ordnance Survey Landranger map series with over 200 to choose from with complete coverage of the UK.
These 1:50k maps join the 1:25k Explorer map tiles already available in RouteBuddy's Online Map Store.
The RouteBuddy Atlas iPhone App is available for download free from the iTunes App Store and allows the laoding and display of OS maps with full support for the 3GS compass and GPS features. Atlas is also compatible with iPod Touch but no GPS features are available on these models.
Maps purchased from RouteBuddy can be loaded from either a Mac or a PC onto the iPhone. With over 600 topographic OS maps available as well as map data for many other countries RouteBuddy and Atlas make a very powerful partnership.
More information is available by visiting RouteBuddy's website here.
Darren Griffin - Editor
I ran the 2013 London Marathon in support of the National Autistic Society see here.
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
rh
PostPosted: Sun Aug 16, 2009 12:20 pm    Post subject: Reply with quote
I've tried one of the 1:50k and one of the 1:25k maps on both the iPhone and the Mac. Only observation so far is that the resolution in the 1:50k maps is low. When you zoom it to a usable level the maps become too grainy to be able to see. However, the 1:25k maps seem fine.
First impressions are very good. As far as I am concerned this is another nail in the Windows coffin for me.
__
Ray Hutchings
SatMap Active 10, Garmin 405, DMC-TZ30 and RouteBuddy, Garmin MAP60CS, Apple iPhone 4 with TomTom & Vauxhall CD 70 Navi.
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Sun Aug 16, 2009 2:25 pm    Post subject: Reply with quote
Ray, what folder did you place the maps into on the iPhone? Also which folders/ or just files go from your map download to the device?
The installation instructions for the PC are non existant, and the need for specific software to open a map download due to it being supplied in ISO format isn't helpful - Mike
PostPosted: Sun Aug 16, 2009 5:21 pm    Post subject: Reply with quote
ISO is a standard format Mike. Blame Microsoft for not being able to handle it out of the box. Most other OS's can.
You should be able to burn it to a CD though, that is what an ISO is after all, a disk image?
PostPosted: Sun Aug 16, 2009 5:28 pm    Post subject: Reply with quote
Getting the ISO image on to the PC was easy, what I am unsure about is loading the map tile to the iPhone - The only way will be a file transfer which requires a jailbroken phone (no real problem) but its something that not all users will want to do just to use an application.
All I want to know is which files need to go into which folders on the device - I am being lazy as I could probably work it out with a little messing around Laughing - Mike
PostPosted: Sun Aug 16, 2009 5:57 pm    Post subject: Reply with quote
From the ATLAS FAQ:
RouteBuddy Atlas contains a built-in file server to transfer maps and data from your Mac or PC. The server can be activated from the Settings panel within Atlas on your iPhone or iPod touch. Once activated, the server URL will be displayed.
Follow the instructions according to the platform you are using (Mac OS X, Windows XP, Windows Vista, other systems) and you will be able to transfer the topographic maps you have purchased from your computer to your iPhone or iPod touch.
Note: Remember to read any “Read Me” files that appear in the folders as these will help you with the installation process.
Map transfer will stall if an incoming phone call is received – this only really presents an issue with the larger maps during busy call times. There are no settings on the iPhone you can suitably use to change this. The best advice is to transfer the very large maps when you expect the least calls, or out of network signal reception.
Does that help?
rh
PostPosted: Sun Aug 16, 2009 6:32 pm    Post subject: Reply with quote
Mike, although I installed the maps from a Mac I just used the instructions from the "Read Me.html" file which is in the iso image. It's just a matter of starting the server inside the RouteBuddy Atlas, navigating to the Maps folder from your PC and dropping the *.rbmap folder into that.
It also helps if you can access the email with the key from the iPhone so you can copy and paste it into the application. It is much faster than typing it in.
__
Ray Hutchings
PostPosted: Sun Aug 16, 2009 8:35 pm    Post subject: Reply with quote
Had to give this a go so just bought my local 1:25k map. The use of an internal server is a very novel and clever solution.
Surely the likes of TomTom and others could do similar to allow install of POIs?
mrg2003
PostPosted: Mon Aug 17, 2009 1:00 am    Post subject: map transfer to routebuddy Reply with quote
I tried the internal server, and the speed was abbysmally slow, it said it would take 50mins!! to transfer the 7MB file. Using WinSCP it took about 5 seconds.
The path on my iphone was I've obfucated my guid
/private/var/mobile/Applications/918439E0- XXXXXXXXXXXXX 580E803282E0/Documents/Public/Maps
and I thought the iphone was supposed to be user friendly.
I notice that routebuddy let you download all the maps, so I downloaded all the UK and will use the demo key to try them out before purchase.
for some reason Barnard_Castle_and_Richmond is 26MB, whereas all the rest are 7-10M
I too found the 1:50K also too small to use, agree the 25K is better, but £17 for a map section - they've got to be kidding.
Mr.G
PostPosted: Mon Aug 17, 2009 8:42 am    Post subject: Re: map transfer to routebuddy Reply with quote
Something wrong then as it took me about 15 secs to txfer my 256Mb file.
Is you're handset JailBroken?
RouteBuddy's map tiles are very cheap in comparison with others!
NickG
PostPosted: Mon Aug 17, 2009 10:00 am    Post subject: Reply with quote
Sounds like you've plugged it into a USB1 port... that's the sort of speed I would expect from USB 1. Try a port on the back of the machine (on the motherboard) rather than any front or 'case mounted' port which are often USB1.
PostPosted: Mon Aug 17, 2009 10:12 am    Post subject: Reply with quote
I transferred mine over WLAN with no issues.
forumhound
PostPosted: Wed Aug 19, 2009 10:58 am    Post subject: Reply with quote
Anyone compared this to memory map (used on a PDA) ?
NickG
PostPosted: Wed Aug 19, 2009 11:10 am    Post subject: Reply with quote
Is it just me, or are there no apps for the iPhone that are even as good as an old Garmin 12XL or EMap? The closest thing I can find is Motion-X, but it's pretty bad compared to a basic garmin - the user interface is pretty awful and many simple tasks (like managing multiple tracks) are difficult or impossible.
PostPosted: Wed Aug 19, 2009 11:13 am    Post subject: Reply with quote
I quite like Motion-X, once you get used to the UI it's pretty capable?
11.053 (15 May 13)
