| Author |
daveg247 Occasional Visitor
Posted: Sat Jan 17, 2009 2:24 pm Post subject: Should a RDS-TMC Receiver work with new v8.15 Map on 710 |
I've updated my dads tomtom 710 with the latest map western Europe map (v8.15), but now the RDS-TMC Receiver not working it connects to the tomtom but can't find a signal.
We've removed the memory card and tried the old one which came with the tomtom and the RDS-TMC Receiver works fine. It worked on the new memory card we have until I installed the new map.
Can anyone help?
Cheers |
| Back to top |
Joined: Jan 14, 2005 Posts: 19636 Location: Blackpool , Lancs
Posted: Sat Jan 17, 2009 2:48 pm Post subject: |
The updated Navcore software messes up a file needed for the RDS-TMC to work, connect the device to the PC and use Windows Explorer to view the contents of the memory card.
In the root of the card will be a file named "mctx.dat" right click this and choose "Open With" then select NotePad.
The contents if messed up will look like:
TX01CVε .PQ'ξVN$dydGz~z
You need to delete all that rubbish and put "22220" (without the quotes) in, save the file and your unit should now work with the RDS receiver - Mike |
| Back to top |
mz500r Occasional Visitor
Posted: Sat Jan 17, 2009 2:54 pm Post subject: |
.  _________________ TomTom 530 App 8.351 UK map v8.50.2781
TomTom rider 2 App 7.901 U.K. v850.
| Back to top |
Posted: Sat Jan 17, 2009 3:01 pm Post subject: |
BUT the OP is asking about an x10 device and the Navcore update applicable to his unit is known to mess up the file which prevents reception. Putting the contents of the file right will cure the problem.
@mz500r - are you having reception issues with your 720? - Mike |
| Back to top |
Posted: Sat Jan 17, 2009 3:16 pm Post subject: |
| Back to top |
Posted: Sat Jan 17, 2009 3:49 pm Post subject: |
Cheers for the help mikealder. I'll give that a go.
Thanks |
| Back to top |
DennisN Tired Old Man
Posted: Sat Jan 17, 2009 9:23 pm Post subject: |
For information Mike, my 920T works fine RDS-TMC wise. The mctx.dat file is garbled, but I also have a mctx.txt file which contains ...
| Quote: | In France using ViaMichelin
In UK using ITIS
In Finland using Destia
In Italy using Infoblu
In Germany using TMCPro
In Sydney, New South Wales, Australia using Intelematics
In Melbourne, Victoria, Australia using Intelematics
In Brisbane, Queensland, Australia using Intelematics |
_________________ Dennis
No TT MapShare (voluntarily), HD Traffic (involuntarily)
TT Support 08451610009 - A) issue, B) challenge, C) problem, D) cockup |
| Back to top |
Posted: Sat Jan 17, 2009 9:27 pm Post subject: |
| mikealder wrote: | | BUT the OP is asking about an x10 device and the Navcore update applicable to his unit is known to mess up the file which prevents reception. Putting the contents of the file right will cure the problem. |
This problem is relating to the x10 device the OP posted, I am going to split out the other posts to a new thread as it is getting a little confusing - Mike |
| Back to top |
Posted: Sun Jan 18, 2009 4:15 pm Post subject: |
mike working fine now.
Only thing i notice was the mctx file is listed as a video cd movie and not a .dat
thanks for you help |
| Back to top |
Posted: Sun Jan 18, 2009 4:21 pm Post subject: |
| That will probably be down to your PC's file association settings, at least you have fixed it, but remember this one for the next update to the x10 because if TomTom don't resolve the issue at their end any new update will probably disable the RDS-MC again - Mike |
| Back to top |
Calomax Lifetime Member
Joined: Sep 30, 2005 Posts: 949 Location: St Martin's, Guernsey
Posted: Sun Jan 18, 2009 11:56 pm Post subject: |
Mike, my 720 has an mctx.dat file that says | Quote: | | TX01CVε .PQ'w^';m#5OϺp<#HpT w | and I have an mctx.txt file the same as Dennis. I can't test my RDS-TMC as we have no RDS radio service in range in Guernsey, although it seemed to work ok last October in the UK.
Do you think I should leave the mctx.dat file as it is please? _________________ TT Go 720 with Navcore v9.430, Europe West Zone v895 on Device - WE v895 complete on SD Card. |
| Back to top |
Andy_P Pocket GPS Moderator
Joined: Jun 04, 2005 Posts: 19389 Location: West and Southwest London
Posted: Mon Jan 19, 2009 4:07 am Post subject: |
| daveg247 wrote: | mike working fine now.
It looks like you are not seeing the three letter"extensions" on the end of the file names.
We usually suggest that you set Windows Explorer (or My Computer, that's the same thing, but NOT Internet Explorer!) to show the three letter file extensions. It makes no difference to the copying process, but it can help sort out other problems if you can see EXACTLY what the various files are called.
In Explorer: Got to the TOOLS menu / FOLDER OPTIONS / VIEW Tab /
In the "Advanced settings" section:-
UN-Tick "Hide extensions for known file types"
I would suggest you also tick "Show hidden files and folders" at the same time.... It does no harm (and is useful for general PC work) but there are no hidden files or folders on a TomTom to worry about.[/quote] |
| Back to top |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2309 Location: Toronto CANADA
Posted: Mon Jan 19, 2009 12:47 pm Post subject: |
Andy, strangely in the Forum I'm a SuperMod for, I've had one or two posters claim they couldn't find the sample mp3 files to delete. Turns out, for whatever reason, they were set to 'hidden'! _________________ David
--TomTom 720 NA map 895 WCE map 840 NZ map 835
--540 WTE NA map 885 Europe_West 885 |
| Back to top |
andy-c1 Lifetime Member
Joined: Feb 05, 2005 Posts: 1030 Location: East Sussex
Posted: Mon Jan 19, 2009 9:23 pm Post subject: |
ok so i've got a 720 with "TX01CVε .PQ'w^';m#5OϺp<#HpTw"
so do i too have to use 22220 as some posts are confusing
thanks _________________ ME TOMTOM 750
Wife TOMTOM 720
active brodit mounts |
| Back to top |
Posted: Mon Jan 19, 2009 9:44 pm Post subject: |
| If you read the OP you will see this is a problem relating to an x10 device, so any prescribed solution is ONLY applicable to the x10 devices which are running different software to the x20/ x30 units - Mike |
| Back to top |
| Back to top |
