| Author |
Joined: 30/12/2002 17:36:20 Posts: 3729 Location: Oxfordshire, England, UK
Posted: Sun Jul 20, 2008 8:04 pm Post subject: NavNGo iGO 8: Sales do not reply, so is Support any good? |
This is for the attention of anybody at Nav N Go.
Having seen the PocketGPSWorld review of the iGO 8 (see here), written by MaFt, I thought that I'd like to buy a copy of iGO 8.
However, I didn't want to buy a new PDA so I emailed Nav N Go's Sales Department to see whether either of my spare PDAs (HP 2210 and HP hx4700) would be able to run iGO 8.
I sent my first email on Friday 27th June 2008 and a follow-up email (nearly three weeks later) on Thursday 17th July 2008. I still haven't received a reply and my email system generally doesn't lose emails!
So firstly C'mon Nav N Go, please respond. If you don't respond to sales queries then what are you like replying to urgent support calls??
Secondly, has anybody managed to get iGO 8 running on either an HP 2210 or an HP hx4700?
TomTom 950 Live, APP: 9.465, Map: Europe v905.4754 (2417.1 Mb); North America 2GB v845.26459
HTC Desire (Android 2.2.2): CamerAlert v1.3.10.754
TomTom 730T, APP: 8.351, Map: W&C Europe 2GB V845.2645 (1758 MB) |
| Back to top |
alix776 Pocket GPS Moderator
Joined: 03/05/2003 14:45:49 Posts: 3967 Location: leyland lancs ENGLAND
Posted: Sun Jul 20, 2008 8:51 pm Post subject: |
the hx4700 may be able to handle it but i doubt the 2210 would handle it _________________ currently using copilot truck COME ON O2 UK GET SOME 2ND GEN WINDOWS PHONES ON YOUR PRODUCT LIST
www.truckerplace.eu |
| Back to top |
mxmaciek Lifetime Member
Joined: Jun 20, 2007 Posts: 108 Location: UK, Nottingham
Posted: Sun Jul 20, 2008 9:30 pm Post subject: |
hx4700 should be able to run with iGo under WM2003SE.
h2210 is running with Intel XScale 400 Mhz what is enough, but i'm not sure if iGo 8 will work with WM2003.
Well... you can try to compare with the compatibility chart: http://navngo.com/pages/global/eng/igo_8_supported_devices and try, if you'll find something with similar specification.
I've tested iGo with Mio 168 & 169 and it's running well, but both are under WM2003SE control. |
| Back to top |
Joined: Jan 14, 2005 Posts: 19636 Location: Blackpool , Lancs
Posted: Sun Jul 20, 2008 9:43 pm Post subject: |
Both Igo8 and McGuider will run on the 4700 but you will have "fun" with the GPS if using Bluetooth, neither application seem to find the BT GPS each time you start either application on the 4700, you have to connect each time by going to BT Device Manager, I have not tried the applications with a CF GPS yet but will do so in the morning. I have always found the auto connect for a BT GPS somewhat lacking on the iPAQ-4700 though so it could be my hardware, although a hard reset of the unit still produced the same problems for connection.
Both applications have no problem finding the built in GPS on the PDA based phones I have tried them on though - Mike |
| Back to top |
| Back to top |
Posted: Mon Jul 21, 2008 10:57 am Post subject: |
Hi mxmaciek,
Thanks for the information. Yes I normally do search the forums first, but my post is also a "heads up" for Nav n Go and a chance for them to reply.
| Back to top |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2108 Location: Midlands, UK
Posted: Mon Jul 21, 2008 6:34 pm Post subject: |
I have also sent iG0/NavNGo 4 emails over a period of 10 days about 3 weeks ago. No reply from them at all. Tried 2 of their email addresses.
I have iGO 8 running on a Mio168, but find it needs at least 38-40MB of program memory free or the map stops but the voice continues in navigation mode.
The iGO 8 software was expensive considering that you can buy a TT for less than a £100 these days. The shop would not refund me for it as I made the mistake of registering it on the Nav N Go web site before I found that I had problems with it and wanted to return it.
Had to remove/uninstall several things on the Mio to get it to run OK because of the memory issue. Would not even calculate the route if over about 40 miles at first. Even now the map sometimes does not turn at junctions for several seconds after the turn if in nav mode.
Seems to need a quite fast processor and lots of memory. _________________
| Back to top |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2504 Location: Rainham, Kent. England.
Posted: Mon Jul 21, 2008 8:05 pm Post subject: |
| Quote: | | I have iGO 8 running on a Mio168, but find it needs at least 38-40MB of program memory free or the map stops but the voice continues in navigation mode. |
The Current list of devices supported by Nav N Go iGO 8: includes MiTAC Mio 168 so it should run OK.
Try a hard reset on the 168 and re-install the software, in case there was a 'glitch' fiest time, then maybe turn off the 3D buildings and lower the terrain resolution, and as when using TT software, turning off all POI's speeds things up. _________________ PGPSW Grand Finale Prize 2010 - TomTom Via LIVE 120 EUROPE. Which my son has stolen since he got a driving job so I'm back with
iGO8.3 with European maps.
Formerly known as Lost_Property |
| Back to top |
Posted: Mon Jul 21, 2008 11:46 pm Post subject: |
| Lost_Property wrote: | | maybe turn off the 3D buildings and lower the terrain resolution, and as when using TT software, turning off all POI's speeds things up. |
I do have the 3D buildings off and the terrain on lowest settings. But I have not tried it without the Safety Camera files, could be them affecting it on my Mio as its old and slow these days compared to newer PDA's.
The other issue with iGO is the safety cameras, specs as we know have the problem of knowing when to turn off the warnings. The mobile are all set to 0 MPH so doesn’t work well, and I have found that about 30-40% of all cameras have the wrong direction set. _________________
| Back to top |
Posted: Tue Jul 22, 2008 1:02 am Post subject: |
| Quote: | | The mobile are all set to 0 MPH so doesn’t work well, and I have found that about 30-40% of all cameras have the wrong direction set. | I haven't found that with 2006+ and we use the same download. Have you got the latest July ones? In June there was an error with, I believe, mobiles and it was corrected a couple of days later. _________________ PGPSW Grand Finale Prize 2010 - TomTom Via LIVE 120 EUROPE. Which my son has stolen since he got a driving job so I'm back with
| Back to top |
Posted: Tue Jul 22, 2008 2:11 am Post subject: |
Must admit that I have not downloaded the July files. Will do now and try over the next few days. _________________
| Back to top |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 11985 Location: Bradford, West Yorkshire
Posted: Tue Jul 22, 2008 9:00 am Post subject: |
with igo8 there are no problems with mobile cameras being at 0?
MaFt _________________ 404 Error - Signature not found |
| Back to top |
M8TJT The Other Tired Old Man
Joined: Apr 04, 2006 Posts: 4838 Location: East Sussex, UK
Posted: Tue Jul 22, 2008 9:14 am Post subject: |
| Pocketgps wrote: |
The other issue with iGO is the safety cameras, specs as we know have the problem of knowing when to turn off the warnings. The mobile are all set to 0 MPH so doesn’t work well, and I have found that about 30-40% of all cameras have the wrong direction set. |
Specs problem is known about by IGO (aparantly) but not fixed . For some reason IGO (Mio) have not allowed a speed to be allocated to mobiles (Wake up IGO) . Our database has about 12500 cams in it. about 6700 have direction info against them (about 54%) most of which is accurate plus or minus about 10 degrees. This means that about 46% of our cams do NOT have ANY direction data (as opposed to wrong) . So come on all you camera spotters, feed MaFt the direction data for the remaining (and increasing) 6,000 odd cams  |
| Back to top |
Posted: Tue Jul 22, 2008 1:51 pm Post subject: |
i was actually going to post a list of all the cameras that need heading data but then realised it would be rather long...!!!
instead i might do a 'live' page where each time you go on it gives a live snapshot of camera id's that need heading data - but it will still take just as long to find id numbers near you!
| Back to top |
Posted: Tue Jul 22, 2008 2:35 pm Post subject: |
| MaFt wrote: | i was actually going to post a list of all the cameras that need heading data but then realised it would be rather long...!!!
How about a page where you enter your location and a radius, whereby cams without heading are listed. Or perhaps something like how my verifier excel sheet works on provisionals, put in SW and NE corner of area to filter in the wanted cams without az?
Just an Idea. Stupid Shouldn't be too much work for you MaFt. (I looked for a suitable 'duck, you idiot' emoticons, but couldn't find one so)  |
| Back to top |
| Back to top |
