Newsletter
Pocket GPS World :: View topic - Acquiring satellite time
p-brain
PostPosted: Sun Jul 20, 2008 5:41 pm    Post subject: Acquiring satellite time Reply with quote
I know this is one of the major concerns regarding the A10. I have had my unit for a few weeks now, and have not been to concerned about the time to acquire satellite lock....until now.
In open countryside, on a sunny and clear day, with the unit fully charged, and positioned horizontally, I tested the lock time 4 times in a row - powering off between each try.
A10 generally finds between 4 and 6 satellites within 60-90 seconds (Av SNR around 35, max SNR around 40) but takes a good few minues more to find further sats and then lock on.
4 trials yielded the following times (from power on, to sat lock): 3m30s, 6m40s, 5m10s and 5m22s.
3 minutes is just about acceptable, any longer is a pain.
I use my A10 for geocaching, and quite often want to use it at short notice, several times a day...so the initial lock time is important to me. Also, I am experiencing quite a few freezes recently, and therefore finding myself having to reset and then wait again for a satellite lock.
Anyway, I can just about cope with the times above.....however....what I find more unacceptable is that if I start walking with my A10 (held in hand, pointing upwards) it takes forever to get a lock (10 mins and over)
Is it unreasonable to expect the unit to lock to satellites on the move in under 10 minutes? (on a clear day, open countryside, some trees occassionally)
I really like this gadget....but I am beginning to get concerned about the initial lock time...especially when on the move.
PostPosted: Sun Jul 20, 2008 6:24 pm    Post subject: Reply with quote
Leave the device switched on with the screen off, this way you will have a position as soon as you power up the backlight. As for walking off prior to a position fix, this is not advisable, any GPS device "time to position fix" will be extended if moving. even walking.
I find putting the a10 on the car roof while changing into walking gear is more than long enough for the device to acquire a position fix, then it stays powered up but with the screen off for the entire day, I don't have any problems using it this way - Mike
p-brain
PostPosted: Sun Jul 20, 2008 6:42 pm    Post subject: Reply with quote
Thanks for the reply. When the unit behaves, and doesn't require resets, I would agree with the above - but if/when it freezes and requires a reset...the long time to acquire a fix (together with having to preferably stay stationary for ~5 mins) becomes a major issue.
I think that had I not experienced freezes this weekend, I wouldn't be complaining too much about the lock time.
The freezing issues I have experienced are a topic for another thread. If I can avoid the freezes, then I think I will be generally happy with the lock time.
4ndynorfolk
PostPosted: Sun Jul 20, 2008 6:49 pm    Post subject: Reply with quote
Have you upgraded to 1.20.?
I've not seen anyone specifically report lock-ups on the v1.20 thread.
p-brain
PostPosted: Sun Jul 20, 2008 6:59 pm    Post subject: Reply with quote
Yes, running V1.20
These are the first freezing issues I have experienced since getting the unit a few weeks back. I think they coincide with me starting to upload multiple POIs to the unit. Not sure. I can't consistently replicate the issue (annoyingly!)
Don't want to go off topic....so may post further details re the freezing in a more relevant topic...but in a nutshell, the unit freezes on switching to the 'pointer' on the compass page.
11.062 (12 Jun 13)
