Pocket GPS World :: View topic - Map Orientation Problems
channy9
PostPosted: Tue Jul 15, 2008 8:37 pm    Post subject: Map Orientation Problems Reply with quote
I'm having problems in changing the map orientation, as at present I am unable to change from the "North Up" View. As when I press the lower left key to change to track orientation, the device "Beeps", and nothing happens with the view remaining "North Up".
What can be done to change the view?
cwmboy
PostPosted: Tue Jul 15, 2008 8:55 pm    Post subject: Reply with quote
Channy9, it is because you are in Advanced Power Mode. Go to Main Menu/Settings/Scroll down to Advance Power Control/select Normal. You should then be able to toggle between North Up and Trail Up using the bottom left button.
I Go To The Hills.............
Garmin 12XL
Garmin Vista
Satmap A10
Anquet Maps 6.2.10
channy9
PostPosted: Tue Jul 15, 2008 9:17 pm    Post subject: Reply with quote
Thanks cwnboy solved now!
cwmboy
PostPosted: Tue Jul 15, 2008 9:22 pm    Post subject: Reply with quote
A pleasure!
Garmin 12XL
Garmin Vista
Satmap A10
Anquet Maps 6.2.10
22.043 (17 Apr 24)
