| Author |
evo99 Occasional Visitor
Posted: Thu Feb 08, 2007 5:01 pm Post subject: |
Here is what you need
A ford ISO adapter
On the rear of the radio, PIN1 circled is the speed sensor .
You will need to connect a wire into the PIN1 connector
Then connect this wire to the green and white wire circled.
This is all that is required to get the SATNAV working. You do not require the reverse switch to be connected, unless you plan on travelling in reverse for long distances. |
| Back to top |
2e0saf Occasional Visitor
Posted: Wed May 30, 2007 10:16 pm Post subject: vnr9000 satnav |
hi there all i am after a vnr9000 satnav disk anyone have a disk they can sell me or tell me where to buy one....???
also the vnr9000 system i am thinking of buying has no disk is the replacement disk all i need to get it back running i have a gps antenna already for example is there any other system software needed etc or shud that be all stored on the vnr9000 itself thank's all |
| Back to top |
incurablematt Occasional Visitor
Posted: Wed Jul 04, 2007 1:39 pm Post subject: 9000vnr ford focus |
I have just purchased this radio, and I need someone with experience to help me with it. I have a couple problems, I am using a gps antenna to connect the unit, and the unit seems to know when i am moving, but the arrow on the navigation tends to point in the wrong direction, therefor doesnt give me a clear indication to where i am going. Also when I put a cd changer in (sony) the changer works until i put the steering wheel controls in then it stops working.
I am not sure if phone numbers can be exchanged on this forum as it would probably be easier to explain over the phone. Could anyone help?
Matt |
| Back to top |
Posted: Wed Jul 04, 2007 6:57 pm Post subject: |
| Quote: | | I am using a gps antenna to connect the unit, and the unit seems to know when i am moving, but the arrow on the navigation tends to point in the wrong direction |
Make sure the speed sensor wire is connected. |
| Back to top |
bps64 Occasional Visitor
Posted: Mon Mar 24, 2008 6:18 pm Post subject: |
| I have a ford mondoe mK2 I put one of these units in it am trying to get my Steering Control unit the one that changes the track and volume and station over ect to work with this unit can any one help me |
| Back to top |
Posted: Mon Mar 24, 2008 9:01 pm Post subject: |
| bps64 wrote: | | I have a ford mondoe mK2 I put one of these units in it am trying to get my Steering Control unit the one that changes the track and volume and station over ect to work with this unit can any one help me |
| Back to top |
| Back to top |
