| Author |
thesouthtoonarmy Occasional Visitor
Posted: Thu Dec 28, 2006 10:58 am Post subject: RAC Sat Nav |
| I have recently purchased an RAC badged Sat nav, looking through this site I noticed that the speed camera database can be installed on Route66 navigate 7 which is what this unit runs. Would the installation be the same?? if any one knows please let me know |
| Back to top |
Posted: Fri Dec 29, 2006 9:08 pm Post subject: |
:D I have now successfulyloaded the speed camera data base onto my RAC sat nav and all works well. Saved me 3 points today!!!
To do this you need to remove the SD card from the device, and connect to your computer with a card reader. Copy all files from the SD card and save under "my documents".then add the pocket gps databadse into the poi greatbritain folder. All this now needs copying onto a seperate sd card and place back into the Nav unit. The RAC card does not take all the info across hense the use of another SD card.
To down load the data base just follow the instructions for the Route 66 pocket PC version (thanks to mike alder) |
| Back to top |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 11982 Location: Bradford, West Yorkshire
Posted: Fri Dec 29, 2006 9:26 pm Post subject: |
Thanks for being a willing guinea pig!
Have now added the RAC unit to the compatibility list. Could you give me the 'model number' or 'name' of the unit?
MaFt _________________ 404 Error - Signature not found |
| Back to top |
Joined: Jan 14, 2005 Posts: 19636 Location: Blackpool , Lancs
Posted: Fri Dec 29, 2006 9:35 pm Post subject: |
| Installation details can be found HERE - many thanks for confirming this works - Mike |
| Back to top |
Posted: Sat Dec 30, 2006 2:08 am Post subject: |
| RAC Sat Nav 110 |
| Back to top |
nato07 Occasional Visitor
Posted: Thu Jan 04, 2007 1:28 am Post subject: camera location downloads |
| Hi man, I tried doing what you mentioned, copying all the staff onto my PC, downloading the camera updates , i copied them in the POI folder and put them on a 2G SD card, but the sat nav wont recognise the new SD card. Any ideas on why or what i sould do next ? thanks |
| Back to top |
Posted: Fri Jan 05, 2007 9:55 am Post subject: |
make sure that you have unzipped the files for the speed cameras as otherwise the sat nav wont reconise the card because there are files it cannot read, have just downloaded the POI's (McDonalds ect) and all still working well so suggest you check the files, delete all info from the SD card and try again, if no luck let me know exactly what the sat nav says and I will try to help  |
| Back to top |
stevest220 Occasional Visitor
Posted: Fri Jan 05, 2007 10:49 am Post subject: Interesting reading, I too have a problem with this unit. |
I inadvertantly deleted some of the POI catagories, instead of removing the POI's. As a result of this the deleted POI's appear to have been deleted from the memory card. The CD that came with the satnav only has the usermanual loaded onto it, not even the map of the UK, how do the suppliers expect us to reload the maps?
Anyway, do any of you know how I can reload POI catagories, and all POI's, back onto the satnav memory card? My PC does not have a card reader, but I should be able to gain access to one as a last resort.
Why is a USB cable supplied with the satnav? doesn't appear to be any use for it.
Once I have found an answer to this problem I will be trying the updates as listed above.
Tks for any info, Steve |
| Back to top |
| Back to top |
tanda Lifetime Member
Joined: Aug 21, 2005 Posts: 617 Location: Gloucester UK
Posted: Fri Jan 05, 2007 2:55 pm Post subject: |
The USB cable is used to connect the sat nav to your PC, the PC will then see the sat nav as an external drive, and you can move/delete/add files as you wish. A card reader does the same thing, but is a lot quicker. I copied my SD card, onto my PC using a USB cable. _________________ TomTom ONE, V2 New Edition (APP 7.903)
with UK & Republic of Irland Maps (660.1219)
Pocket GPS World Speed Zoned Camera Database With Liz Voice Warnings.
Lexar Premium 2GB SD Card 60x Speed.
TomTom HOME 2.9.1.2780
Vista Home Premium
Garmin etrex |
| Back to top |
Posted: Fri Jan 05, 2007 3:40 pm Post subject: camera update on RAC satnav110 |
oh thanks man, i managed to transfer the camera updates onto the original Satnav110 SD card and it worked, its alerting me of all the other camera locations that weren't there, but three times a message came on saying "it had performed an illegal operation and will shut down" . It just froze like that and i had to start the navigation again.Do you know why it was doing this ? Maybe its because i had not unzipped the files, I've just done that now and I'll see how it works |
| Back to top |
Posted: Fri Jan 05, 2007 4:02 pm Post subject: |
This could be related to the read / write speed of the 2GB card, I notice you say that you copied all the files on to a 2GB card, was this the card supplied with the device or an after market purchase?
Not all card offer the same performance and some sat nav devices can be quite "picky" as to the type of card, although with your new unit there is little known about this issue (if it is infact card speed related) - Mike |
| Back to top |
Posted: Fri Jan 05, 2007 9:23 pm Post subject: Tks for the info |
I'll try the link and post my progress at a later date.
Steve |
| Back to top |
Posted: Fri Jan 05, 2007 11:30 pm Post subject: rac satnav110 |
when i realised that the SatNav was not recognising the 2G SD, i used the original one that came with the item. I opened the POI folder and attached the camera locations that i downloaded. I haven't tried it lately since I added the unzipped the camera location updates. I didn't realise that when you download them, they are saves as zipped compressed files  |
| Back to top |
Posted: Fri Jan 05, 2007 11:35 pm Post subject: Re: Interesting reading, I too have a problem with this unit |
I've got my original POI from the RAC satnav,if you fail to find them elsewhere, I could e-mail just the POI folder to you. Let me know!  |
| Back to top |
| Back to top |
