Newsletter
Pocket GPS World :: View topic - CheckPOInt.ov2 Icon
CheckPOInt.ov2 Icon
wilx
PostPosted: Tue Jan 13, 2004 9:29 am    Post subject: CheckPOInt.ov2 Icon Reply with quote
Have Added the cameras on the Nottingham Ring Road (sent to you today!) , but would like to have them show an Icon on the map.... is there anyway to do this? Tried copying the one from the Pocket Gp Cameradatabase and renaming to CheckPOInt.bmp.... but no luck
TIA
DavidW
PostPosted: Tue Jan 13, 2004 11:04 pm    Post subject: Reply with quote
That should work - though don't forget to enable the POI category in TomTom Navigator 2 using the Properties screen (from the File menu in anything other than Navigator mode, or use the button in the Navigator Menu in Navigator mode).
You may also need to exit and restart TomTom Navigator - File -> Exit in anything other than Navigator mode, or the Exit Application option in the Navigator Menu in Navigator mode.
wilx
PostPosted: Wed Jan 14, 2004 12:19 am    Post subject: Reply with quote
No, still doesn't work, shos no icon in the POI list in the properties secion either
DavidW
PostPosted: Wed Jan 14, 2004 1:07 am    Post subject: Reply with quote
Delete what you've copied and copy again in case it's corrupt. Make doubly sure that you've put the file in your map folder, that the name is CheckPOInt.bmp (not CheckPOInt.bmp.bmp - you may have file extensions hidden and haven't realised that you've got a double extension).
Quit and restart TomTom Navigator again - that really should get things going.
wilx
PostPosted: Wed Jan 14, 2004 9:13 am    Post subject: Reply with quote
Yeah thanks, that sorted it out...was called .bmp.bmp ! Is there anyway to turn off not showing extensions for known types as in windows on a Pocket PC????
DavidW
PostPosted: Wed Jan 14, 2004 5:04 pm    Post subject: Reply with quote
Using the built in file manager - no. I recommend Resco Explorer 2003 - it's much more fully featured (you can turn off extension hiding!) as well as adding the ability to deal with Zip files. It's not freeware, but like most Pocket PC software, it's not expensive.
Details are available at http://www.resco-net.com/explorer.asp.
11.063 (19 Jun 13)
