BAVC10 Lifetime Member
Posted: Mon Sep 18, 2017 2:32 pm Post subject: |
Doesn't GE give the options for the area you want to install?
There used to be a drop down box so that you could download just UK&I even though the unit may have had a much larger mapset supplied by default.
I've a DriveLuxe 51 which comes with Full Europe (is larger than Western) mapping and that is split between North and South. The main file is gmapprom.img which is usually found in the System folder _________________ DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3 |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Mon Sep 18, 2017 2:48 pm Post subject: |
BAVC10 wrote: | Doesn't GE give the options for the area you want to install?
Only if your device won't accept the full map due to space constraints. Garmin seem to take the view that if someone buys a device with a full EU map then they want the full EU map so that's what they'll get. It would be good if there was an option to select different mapsets though, MapUpdater (Garmin's previous map updating program) did allow that but it doesn't seem to work with newer devices, at least it hasn't whenever I've tried it.
The crazy thing is that if there isn't sufficient room Express does offer you mapset choices! _________________ Where there's a will ... there's a way. |
Posted: Mon Sep 18, 2017 3:38 pm Post subject: |
Ok - haven't tried downloading anything other than the full European maps for a while so they must have changed this.
Presumably, the op. with the issue could 'trick' GE into thinking it was full by making a copy of a large file, renaming it and then GE would offer the smaller map sets. _________________ DriveLuxe 51 LMT D - Firmware 6.70
Posted: Mon Sep 18, 2017 3:54 pm Post subject: |
Yes, that's the normal workaround. _________________ Where there's a will ... there's a way. |
Kremmen Pocket GPS Verifier
Posted: Tue Sep 19, 2017 8:43 am Post subject: |
Done
2599 now just Western Europe with 2Gb rattle room _________________ Satnav:
Car Average MPG :
b33jay Lifetime Member
Posted: Sat Sep 23, 2017 5:39 pm Post subject: |
I have a 2589 with full Europe. The latest update is 7.9GB but the device shows 12MB free of 7.02GB so there will not be enough space as I have previously deleted all the unwanted bits.
I decided to see what would happen if I went ahead with the update and, in view of the comments above, expected to be offered a split of the Europe maps but the full Europe downloaded and it now shows as 11.1MB free of 7.02GB.
One problem is that the north/south split of Europe puts the UK in the north mapping whereas it's probable that most UK tourists would prefer it in the south along with France, Spain and Portugal the more popular destinations. |
Posted: Sat Sep 23, 2017 5:56 pm Post subject: |
The split shouldn't be an issue, your nuvi will simply treat it as one map. _________________ Where there's a will ... there's a way. |
Posted: Sun Sep 24, 2017 6:23 am Post subject: |
If you don't need full Europe then consider Western Europe or even UK&I.
It just gives the unit some breathing space without needing a card. _________________ Satnav:
Car Average MPG :
M8TJT The Other Tired Old Man
Posted: Sun Sep 24, 2017 8:04 am Post subject: |
Like have asked before. Does it actually need much breathing space? Do you have any evidence for this? |
Posted: Sun Sep 24, 2017 8:21 am Post subject: |
I don't believe you need much free space, what you see is memory that your device uses for storage, there is other memory where the operating system resides.
The advantage is that future map updates shouldn't then need a SD card. _________________ Where there's a will ... there's a way. |
Joined: 30/12/2002 17:36:20 Posts: 4914 Location: Oxfordshire, England, UK
Posted: Sun Sep 24, 2017 9:25 am Post subject: |
Is there any disadvantage (or advantage) in a Garmin using (or not using) an SD card?
It's a long time ago but I'm reasonably sure that I used to use an SD card in my TomTom 950, with had no trouble having the maps on the SD card and the OS on the internal memory.
Garmin Camper 770 LMT-D |
Posted: Sun Sep 24, 2017 9:28 am Post subject: |
I think you're correct. I've had maps etc on a card for a while and never noticed any issues. _________________ Where there's a will ... there's a way. |
Posted: Sun Sep 24, 2017 9:31 am Post subject: |
I always treat the Nav as a mini computer.
Give it some space to work and reduce the database size (maps) and theoretically it should perform better. _________________ Satnav:
Car Average MPG :
Posted: Sun Sep 24, 2017 9:55 am Post subject: |
I'm going to 'fill mine up' and try it. I'll report back when done. |
Posted: Sun Sep 24, 2017 10:03 am Post subject: |
As posted though, the difference is probably not noticeable to the human eye. _________________ Satnav:
Car Average MPG :
